What size tires are those? It looks great!
Oops!! 305/55 solid tire does rub in reverse at full crank
Any pics down the side? Would love to see how much the tires do or don't stick out with that offset. Deciding between a 0 offset or +18 offset rim
Yes I do!
Looks like the stick out about an inch right?
So a +18 offset would suck it back in 3/4" correct?
(I work on a construction site, don't want rocks/mud and crap all over the side of my truck)
2" front only Rough Country level installed. Stock Z71 wheels and tires. Took me a little over 2 hours with limited knowledge and tools.
Nice. How's it ride with the front leveled now?
Edited by cato
That would be awesome! Thanks!
Hey, sorry I haven't followed up on this yet; just been swamped with work. I will try to get some pictures tomorrow, but at the latest Thursday.
Josh
installed RC 2" level kit and put the Goodyear Duratrac 275/60/20 tires. does not rub but gets real close so I zip tied the liner .will post pics as soon as i can charge battery on camera. it rides better than stock.
Josh
No worries, I appreciate it.
Is it alright if I put on my 2 inch rc kit on Saturday and drive it for 4 days until the alignment it won't make a difference will it?
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,464 Guests (See full list)
    • I have 2 choices.
