Nice combination! I am considering a similar setup. Is the difference in handling or gas mileage significant?
Thanks Donstar! I've only been driving on it for a day, so I don't have much to go off of ha. but so far I haven't noticed any big changes! It handles just as well as it did before I had the kit and tires on.
Anyone running 275/65/20s with the RC 2.5" kit on stock wheels?
I'm looking at the Toyo AT II the BFG KO2 and the Mickey Thompson ATZ and would like it know if anyone is running a similar size tire and can tell me if it rubs (turning, reverse, gravel/bumpy roads, offroad) and if you had to trim.
2014 GMC RC 2.5"
Thanks in advance
Edited by Patflynn8734
So I'm thinking of installing the Rough Country 2.5 inch leveling lift kit, 20X9 Worx Beast wheels with a +18 offset and 35x12.5R20/E BF Goodrich All-Terrain T/A KO2 tires on my 2014 GMC Sierra 1500 SLE Z71. Would I have any rubbing issues?
That will rub bad and you will have to cut plastic and probably some metal. It will look goofy too on only 2.5 inches. The minimum for 35s to fit with little trimming is a 4 inch lift. Go with a 295/55r20, 305/55r20 Max
Sent from my treestand using Tapatalk
Thanks a lot. So a 305/55R20 is basically a 33X12.5R20?
Exactly. That's the biggest tire you should consider to run if you don't want to do significant trimming. I would actually say go 295/55r20.
I'm going with 285/55r20 toyo at2 xtremes and the sticker toyo puts on the tire says 33x11.50, on the site it's inflated dimensions are 32.5x11.7.
The 295/55 you more than likely will not have to trim any, and it's a plenty big tire. It'll fill the wheel well up nicely without it looking stuffed
Post a pic after you've got them on.
Will do. Won't be for a while though as I'm currently building a house, hope to do in by the end of the year. Here is a pic of a Sierra with a 3.5 level and 285/55r20. So picture this but 1 inch less and white. That's my set up, same wheels too91349dd931e7a3c0dbdf9f50a8810a42.jpg
That will look awesome!
I went ahead and pulled the trigger on the BFGoodrich All-Terrain T/A KO2
I liked the look a little better, had good success years ago with BFG. Figured both were good. My main tire shop (Discount Tire Co.) both had service guys tell me the BFG seems like better tire. Less problems they see. Who know....
2" level kit being installed tomorrow, and 285/55/20 BFG on Wednesday! Can't wait.
We need some pics man! Did you get them on? I'm going for the same set up
So I got the 2.25" ready lift put on and I am very pleased. I'd say my truck is done for now. Before I go bigger on tires I'll upgrade the stereo as the stock speakers are a joke [emoji20]
That looks good!
Sorry for the delay. I tried posting last week using the tapatalk app, but it said my pictures were too big. I have since shrunk the photo. Here they are. I must say, what a huge and awesome change. Makes a nice luxury truck (SLT model) feel like a real truck after having the 2" level and new tires.
I had the 2" "Zone" level put on the front. For the tires, I put 285/55/20 BF Goodrich A/T KO2.
Pros
-Truck looks 10x better with the level. (Even with factory tires still on before I put new tired on it looked better)
-New BF Goodrich A/T K02 tires look great on the truck. Not over the top aggressive, but not boring either.
-No rubbing at all.
- Perfect height for what I was looking for.
Cons
-looks about like 1.5-2mpg difference - But I have mostly only driven city miles. With gas $1.80 it's no biggie.
-Noise is not an issue, but the tires are louder than factory. With radio on, you barely can even hear them.
-Slightly rougher ride when going over potholes or traintracks, but not much difference at all.
Overall, without a doubt I'd do this same setup again. It's not too high, not too big tires, just perfect for what I was looking for. I didn't even tell my wife I was doing it. She even said, "Man look at those tires, that looks really good...." she doesn't even pay much attention to my vehicle either. So she noticed. :)
Here is very similar picture as posted before.
I really should do a straight shot vs the angle shot with tire turned. This was just how I had it in the driveway when I decided to take the picture.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
