Just got Readylift 2.25" on my 2016 2wd gmc Sierra. Running 295/55/20 on stock rims. Tires are rubbing A arms. Has anyone used the 1/4 or 1/2 spacers?
Sent from my SM-G935V using Tapatalk
I wouldn't use spacers, especially on a truck. Those won't be too bad but still, you are far better off getting less positive offset wheels.
Sent from my treestand using Tapatalk
What offset would I need to run?
At least +18 for no rubbing
Well + 18 now has tire rubbing on sway bar....
There's a ton of guys running 295s and +18 with no rubbing, not sure what to tell you, also know somebody running 305/65r18 on +18 xd wheels on a RCX 2.5 level no rubbing
Edited by MOhunter92
Well not sure if it's the LT295/55/20 Toyo Open country's aggressive tread, but seeing how I've got the newer Stamped steel control arms and almost everyone I have talked with have to swap control arms for lift kits. Wondering if this has something to do with it.
Wheel shop it gonna order one more set of rims and see if can make them work. If not may have to go to smaller tires.
I bet that's the issue. Any level over 2 inches has issues with those arms, has to do with upper arm not having enough clearance not to hit the strut. I know you haven't said anything about that and I'm sure the sway bar isn't located closer to the tire with those, but that has to be what the problem is
Not sure, but first tire rubbed on control are now with new wheels, rubbing on sway bar....find out next week.
That's really weird, doesn't make much sense.. I'm not sure, I'm just glad I have the cast steel arms on my 16
Finally got around to getting the RC2.5 installed on my truck.
Waiting on the new wheels to be finished getting drilled and then will take another picture.
Before: 595327548fdfd7ddf4dbf9889b187ea4.jpg
After:
Edited by Wazbe
theres a guy in my area with the 2.5 rc kit and hes running 285/65/20 with the stock 20" wheels. looks really good. does anyone else have this setup? any rubbing issues?
2016 GMC 1500 SLT 2wd
2.25 Readylift Level kit
KMC XD Rockstar II 20x9
295/55r20 Toyo open Country AT II
GM CAI
ARE Z series Camper shell Ordered
    LeeBob
    LeeBob
  • Who's Online   0 Members, 0 Anonymous, 950 Guests (See full list)
