What about a body lift? I have no experience with them, but they look like reasonable solution to a little more height.
is there any way to get another little bit of lift on truck. i currently have a 2.5 inch level kit on truck all is good with it . but would like to maybe go 1/2 to 1 inch more anyway simple way to do this . im always an inch short lol
Body lift would work, but there is quite a bit of labor involved in installing those, and IMO it makes the trucks proportions weird.
2016 GMC Sierra 4x4 - Stamped Steel Control Arms
Anybody running RC 2.5 w/ 2" rear block, 22" GMC Factory (CK162) with Toyo Open Country 33x12.5 R22
Looking to find out if any rub or what trimming needs to be done here.
Called RC and was informed there would be minor rub.
Any input is appreciated.
I just purchased a 2016 GMC Sierra 1500 Denali.. Looking for recommendations on what leveling kit I should go with? I am believe there may be a difference in suspension between the Denali and the SLT/etc? I have the stock 22" wheels/tires.
So far thinking the RC 2" (SKU 1311), thoughts?
Thanks in advance.
Thanks in advance.
I did the Rancho quick lift 2 inch strut
Looking for anyone with the combo I'm hoping to do. Searched for a while and can't find. Thanks for the help!
2014 Sierra
Double Cab
All terrain
20" wheels
2" RC level
Toyo OC AT2 275/65/20
I know the 60 will fit from reading but curious about the 65?
Thanks again
2014 Sierra SLT
2.5" Front Level
2" Rear Block
18" Rims 33" Tires
Minor rub at full lock
Edited by dragonwheelies
2014 Sierra SLT
2.5" Front Level
2" Rear Block
18" Rims 33" Tires
Damn...just...damn. That looks really good. Magnum Hi or Low Pro headache rack?
LowPro! But looking at the photo it kinda looks like the Hi lol
2014 Sierra SLT
2.5" Front Level
2" Rear Block
18" Rims 33" Tires
That thing is SO CLEAN!!!
Great job!
2014 Sierra SLT
2.5" Front Level
2" Rear Block
18" Rims 33" Tires
What's you're wheel specs, just curious as you said you rub.
Sent from my SM-G930V using Tapatalk
18x9 +22 (not 100% sure on the offset) But it rubs just slightly when going into a driveway.
Great job!
Thank you! :)
Thank you! :)
Tires look too fat for 275/70 or 285/65. Are they 305/65? or 295/70?
No they are actually 275/70's. Might be the shadows making them look larger lol
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,266 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
