Using rear camera assist......
OK, maybe it's just me but I don't think so (as the folks at the dealership had no answers). I bought the 2014 Silverado Crew Cab LT a couple of weeks ago, with the Sports Package and Trailering Package.
How does one properly use this feature, and specifically what do the orange lines represent? I assume distance-if so, how much? I've looked all over on line and on this site and can't find any discussion of it. I have owned trucks before and at 50 I'm certainly capable of driving/parking without it but figure what the heck, it's there. It looks like I'm right on top of the vehicle behind me when I use the camera, and then I hop out and I'm 5 feet away, lol.
BTW, I read through the thread about all of the issues people are having with the 2014s and I'm glad to report, so far, zero issues here. I went over it with a fine tooth comb before taking possession and honestly it drives like a Caddy compared to my 2011.
Scary the dealership had no clue so I thought I'd give this board a shot. Thanks in advance.
I mostly use it to make sure I'm not backing over anything like a small child, other wise I use my mirrors and back window.
Thanks guys and Joe I agree. I think that's probably how/why I'll end up using it. I just find it funny no one at the dealership has a clue what the lines mean and how to use it properly. I think I'll disable the lines feature and just use the warning alerts whenever I'm parking in that tight a spot.
My wifes 2013 Tahoe has these and from what I gather its very similar to what's on the 2014s. Not sure what the lines represent distance wise but you have to be careful as things come faster than you think. I have the backup camera on my 2011 but it has no guidance lines.
Sent from my Galaxy Nexus using Tapatalk 2
I believe the lines are there to provide perspective of the vehicle's width at distance and the size of an object behind and how rapidly you are approaching it.
I think you are over-anaylizing something pretty simple, IMO.
Not in the OM I guess. On my 09, it has the warning lights and audio beeps. Over time, I began to understand the distance in relation to the warnings and how much room I had. U will too on this system, after some use.
the orange lines represent where the truck is going. You just have to get used to it. Once you do or use it to hook up a trailer, you'll never want another vehicle without one.
Hello,
I see that you have a few questions about your new vehicle. Private message me including your questions and your VIN. I would be more than happy to assist you.
Safe travels,
Jennifer T.
GM Customer Care
If you wanna know distance, get a tape measure.
Orange lines represent vehicle path. If you purchased a up scale truck, it has yellow lines that represents the yellow brick road to the pot of gold at the end of the rainbow.
:lol:
Take a few minutes to play around with it and place some objects behind the truck and move to them line up with the lines. Then you will have a better idea of the distance behind your truck when you back up.
wow. thanks for the great advice. now go shoot yourself.
great advice. thanks mike.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
