Pics of new 2014 Double Cab
  • Replies 60
Thanks for the pics. I guess I may switch to looking at the crew cab now since that rear floor hump looks even bigger than the GMT-900 trucks. I just hate to have the shorter bed. Yes I know I can order a longer bed but I like the length of the double cab.
was thinking the same thing. Floor hump seems really big.
yes... alot more "humps" in the floor when compared to my old Silverado x cab. No issue for me.. as I only have a dog that may ride back there every once in awhile. However, I did site back there and I was fine for me (5'9) But I wouldn't want to sit back there on a long trip somewhere..
Thanks for the rear pics. It doesn't look as bad as I thought it would be so I might be able to step down from a crew cab since no one offers a 4 door half ton with a real bed.
What is a real bed? You can get a GM crew cab with the 6.5' bed as well as Ford. Only 8' bed on a GM now is regular cabs.
Very nice truck! And great idea on the 3M paint defender. I wish I'd done that on my '11 with it's matching white front. I do miss the suicide doors on the ext cabs though, Wish they'd kept those, and left the 4 regular doors for club cabs. They'd really be different in the market that way today. Oh well.
A few things..
1. 3M paint defender - bad mistake. After one wash it started to bubble a little.. ended up having to remove all of it....which took a half a day to do. Stay away from this stuff.
2. Yes you can get a crew cab with the long bed.. but it's like driving a bus. And if you get a short bed crew cab.. then add a tool box you're left with a only a few feet of usable bed space.
It's all personal preference. In my opinion the double cab stance just sits better that any crew cab... regardless of the bed size. It was a no brainer for me since I don't have have kids. Plus with the tool box added.. I still have a decent size bed to work with.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,315 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
