Doublecab rear floor question.
Why in the world did GM redesign their trucks and not flatten out the floor in the doublecab? I mean the crew cab floor is better (flatter) than the doublecab and the crew cabin is a longer cab. Also I know the old suicide door set up in the GMT-900 was a pain for the rear seat folks to get in but, the new doors are rather small. I'm 6'3" and did not even try to get in through the door. Gonna look at them again when I get a chance too see if my perception was wrong.
I'm not sure they intended for a 6'3 man to climb back there....lol. You would probably even be a little tight in a crew cab being that tall. I'm 5'8 175 and I can get back there ok... riding back there wouldn't be bad for an average adult.. but not for more than an hour. I wish they had a center armrest in the back seat ( like they did in my old Silverado) that makes riding a little more comfortable. Guess it's not a big deal as I will never be the one riding back there.
As for the floors ... I hear you. I wanted to look into added a sub box under the seat on one side. But all the humps, etc in these new floors makes it difficult.
Just wanted to say I am 6'3" and weigh 300 lbs and I can get in the drivers seat and adjust it like I want it and then get out and sit behind the drivers seat in the crew cab and still have several inches of leg room left!
I agree... don't see single cabs being made for much longer. Cant imagine the demand is that great.. other than fleet vehicles.
They wouldn't have offered it after the redesign if they intended to drop it. I didn't pay much attention previous but I see a lot of reg cabs that are clearly personally owned. Especially Ram Express trucks and F150 STXs.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
