6.2 numbers released
Once again just like with the SS GM aleinates the younger buyers by making the vehicles we want so unaffordable that only a retiree can buy them. :rolleyes:
  • Replies 62
Makes me seriously consider staying with GM for my next new truck. Wow! But like a previous post mentions, will you even be able to tell it with all the nannies put in to protect the delicate drivetrains they have now...
Lots of people buy 50,000 dollar trucks. That's why the auto makers are making so many of them.
I won't be. The next new vehicle I'll probably be able to afford is the Code 130r lol! :lol:
Gonna have to wait a while for that one. :lol:
The longer the better. Going to want something with a good combo of fuel mileage, and fun. I think it would fit perfect as long as the price is right.
On another note, is anyone planning on buying one of these trucks with the 6.2 asap?
Jeez if this is what the "half tons" can do what the heck are the 2500s and 3500s going to? The 6.2 #s blow the doors off my '06 2500 with the 6.0. HP,TQ, MPG, and max towing. Heck the towing #s are close to dad's '09 3500 with the duramax. What happened to the 1500 for driving/light work, 2500 for towing, and 3500 for hauling mentality? Now it seems that majority want a 1500 to do everything and then wonder why prices for them skyrocket. Probably my biggest peeve with the truck industry. Nice numbers nonetheless though.
No matter what the ratings are, I don't think I'd ever be comfortable pulling that much with a half ton. Not to mention many things you would pull that weigh that much (gooseneck flatbed, stock trailer) have a tongue weight way over what a half ton is capable of carrying, especially when loaded. I doubt many will want to put a 5th wheel hitch in their 2014 either. Once you pull a lot of weight with an HD you don't want to use a half ton to do it!
Exactly. I would get the 6.2 just for the joy of having that much power. :)
Another issue is how long until the 2500/3500 weight limits go so high that you need a commercial license?
Sent from HTC's "too hard to implement ICS" Inspire 4G running JB
I'm wondering if they have an iron block version in the works for the HD's. The AFM is seamless now, unlike the previous gen.
I'm glad they have improved the AFM. I'm not a fan of it on my 2012. And yes, they will probably stay with an iron block in the HD's, like they have in the past.
It will be in the 2500's. Afm is easy to eliminate :) Ryan
Good to know. Yeah, I really don't like the AFM on my current 5.3. I'm too nervous about warranty issues with an aftermarket tune, so I may just invest in one of the Range V8 modules.
why are some of yall freaking out about them "nannying" the 6.2. just get a tune and that will fix itself.
Honestly if the AFM is as good as it is on the 5.3 you won't even notice it. Seriously I can't tell the difference between V-4 and V-8 mode in my 14 Sierra...
Sent from my SCH-I535 using Tapatalk 2
The longer the better. Going to want something with a good combo of fuel mileage, and fun. I think it would fit perfect as long as the price is right. On another note, is anyone planning on buying one of these trucks with the 6.2 asap?
Daryl, I just ordered my Denali with the 6.2 this morning. It is Sonoma Red and loaded out except 4wd and sunroof. I have no use for either one of those. Now, it will just be a waiting game.
What was the bottom line if you don't mind me asking?
And how much extra for the 4x4 and hole in the roof?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
