6.2 numbers released
  • Replies 62
So... you can get it with the "max tow pkg", but only in high-end trim? Do folks really buy $50k "half tons" to tow heavy stuff? GM needs to get their heads out of their hinies, and put this motor in a LT / SLE trim 1500 truck. Then again, the new 5.3 w/ a 3.73 axle would be *plenty* of power for the rest of the truck to handle when towing at max ratings. GM originally announced that the "max tow" would be available w/ the 5.3, but I haven't seen that option yet. Did I misunderstand?
5.3 3.73 NHT will be available later this year.
That torque rating is impressive! Too bad they went the way of Ford, and only offer it in high trim levels now. Glad I bought my 11 even if it has a significant less amount of torque.
That may be the tipping point for my personal interest in the new trucks. We shall see...
I think it's stout with the 3.08's, can't imagine how it would run with 3.73's.
It's not E85 capable?
Ryan
Seems that way. I read somewhere that the credit automakers get for E85 vehicles is set to expire so they will likely stop manufacturing engines that can run it and in turn, you'll probably see E85 go away.
It's not E85 capable? Ryan
According to the GM training manual, but the training manual also said 425/450, and now the official numbers are 420/460. They could send out an update.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
