6.2 numbers released
Curious of it will be available on the Z71 LTZ. This is engine I want. I don't care about E85 compatibility especially if I need to tow the weight that engine is capable of.
Sent from my Galaxy Nexus using Tapatalk 2
  • Replies 62
Seems that way. I read somewhere that the credit automakers get for E85 vehicles is set to expire so they will likely stop manufacturing engines that can run it and in turn, you'll probably see E85 go away.
Yes! Die E85!!! Sorry Ryan.
I'm going to have to drive a new 6.2 when they're out.
Nice numbers, but just like most people I think it should be offered in lower trim levels.
Im thinking the 355Hp 380ft/lbs 5.3L will be plenty for me
Curious of it will be available on the Z71 LTZ. This is engine I want. I don't care about E85 compatibility especially if I need to tow the weight that engine is capable of. Sent from my Galaxy Nexus using Tapatalk 2
I'm sure it will be with 3.08 or 3.42's, you just won't be able to get the NHT package with Z71 if they follow what they've done in the past.
Those are similar specs to your old SS stock
Big 3 Comparison -
GM Sierra / Silverado 1500 - 6.2L 420hp 460tq
Ford F-150 - 6.2L 411hp 434tq
Ram 2500 - 6.4L 410hp 429tq
yep and that was plenty of power for me. Hell Im happy with my LQ4 with 300hp and 370 ftl/lbs
My question is how much is GM going to nanny the 6.2 trucks? Would the consumer even be able to tell and really be able to use the power, or will GM nanny it into oblivion?
Maybe less with the new rear axle. I wonder if the NHT will get the 6l80 or 6l90 trans?
I'd love to see a non-afm version of this beast in the new HD's....with 4:10 gears! That might make me switch over to a 2500. Gas mileage be damned...that would be a blast to drive.
I'm wondering if they have an iron block version in the works for the HD's. The AFM is seamless now, unlike the previous gen.
It will be in the 2500's.
Afm is easy to eliminate :)
Ryan
Interesting numbers. It'd be really impressive if the MPG ends up being around 21/16.
Never had much of a use for the 6.2 in my truck other than it being quicker, and I'll appreciate the better MPG when I pick up my '14.
