Preset Stations
ibleedgreen
Dumb question....So somehow my presets used to stay on the bottom of the radio/xm screen all the time. And now they are gone, I can only get to them by pressing the tab that raises them back up. Once I exit they are gone again. I've gone to the home screen then settings and you can manage them and the amount that you can scroll through but nothing seems to get them to stick at the bottom. Ideas?...thanks!
  • Replies 30
Place your finger on the bottom where the presets normally are and drag up. I had the same issue a couple weeks ago and it took me 2 days to figure it out lol
I hope this is the fix you need anyways. Apparently you can hide the presets completely or drag all the way up to show all 15.
Yep I did the same thing, if you can't figure out how to drag it up, you can always go into the settings and do a factory reset
Haha, I knew it would be that simple! That's what I get for letting somebody drive my truck. They came back and I was like wth did my presets go? lol
Worked great thanks!
Make sure that it's set to more than 5 presets in the settings area. Then, on the radio screen, drag the presets up and then set them to what you need by selecting the station and then holding what ever preset button you want the station set to.
also a dumb question....... how do you set more then the 5 or 6 that are blank at the bottom?
Like Tim said....press the home button, then settings, radio and you can adjust the presets in there. From like 5 to 60 I believe.
  • 1 month later...
Hi to all. I traded in a 2007 Yukon XL for a 2014 Sierra 1500 SLT and really like it. Does anyone know if you can name a radio preset like you could in my Yukon? For example "POPS" instead of "XM76"?
Settings
Radio
Manage Favorites
Rename
Plasman,
I see that you awesome fellow forum members were able to help you with changing the name on your preset stations. I just wanted to let you know that GM Customer Care is on the forums as well and are happy to assist with any general questions or concerns you may have about GM products. We are only a private message away!
Jennifer T.
GM Customer Care
I found the volume and presets buttons on the back of the sterring wheel tonight. :)
Heh when I did my initial test drive, the dealer told me those were manual shift paddles. Of course now I know that the shifting is on the shift lever.
How are y'all making the presets completely disappear / hide???
I rarely use the radio, mainly just the flash drive, so the presets are clutter to me.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 758 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
