Install went well. I will try to post photos this week. A couple of things:
1). Unless you want to cut the factory hose to re-use the snap lock connections, you definitely need hose clamps to connect the black hose to the nozzles on the engine. I did them on the catch can end for extra stability but they really aren't necessary there.
2) the clean side lines had oil in them but the throttle body was clean and dry and the airbox was clean and dry. I have the 5.3.
3). I'm noticing an increased vibration in the gas pedal at certain gears and RPM's but cruising it's not there. I will keep my eye on that.
I guess to be fair I always felt a slight vibration but it seems more pronounced now. I dunno....
It's all in your head
Ryan
I'm sure you're right! How do you guys post pictures on this forum usually?
Is the middle valve on the RX can supposed to be able to be rotated? Because I had to rotate it 180 degrees to get everything to fit right because it was backwards based on the pictures everyone else here has been posting. Seems fine, just wanted to be sure.
Edited by Silverado-Hareek
I took a peek under the hood today. I took the attached pictures, on these pictures where is the line I need to replace when installing a catch can? My Sons looked and they believe I may need two. Both sides have a line going from the valve cover to the intake. What is the scoop? I'll post the 2nd picture separately it won't let me do them at the same time. . Thanks.
Here you go check out post #153: http://www.gm-trucks.com/forums/topic/154204-oil-catch-can/page-11
The lines you are taking pictures of are the clean side lines of your valve covers. RX makes a clean side separator for the driver's side line (pictured above) but they do not have a solution for the passenger side line (your second photo). According to what I've read on this forum and other internet research, the catch can will catch 99% of the crap going into your intake and caking up on the valves. The clean side separator will help even more, but again there's no solution yet for the passenger side. I installed my RX can yesterday and I checked both of these clean side lines. They had some oil in them but the airbox was pretty much dry and clean and my throttle bottle was spotless. I have the 5.3L V8. If you have the 6.2L V8, your throttle body will have oil on it because the inlet for the PCV system is on top of the throttle body rather than on top of the intake manifold like on the 5.3L engine (see pictures in post #153 I linked to above).
Ryan
Ryan,
I don't think it's all in their head. After I installed the RX can in my truck, there was a noticeable vibration in the gas peddle at certain RPM's. My wife felt the vibrations too when she drove the truck. Believe me it's not imagined.
What I did to solve the problem is to move the RX can as far back as I could in the slots on the bracket that mounts the can to the brake booster. I had originally mounted the can forward (toward the front of the truck), to allow easier access to the oil dip stick. Once I moved the can back (towards the firewall), the vibration went away.
I think the check valve on the can, which is mounted close to the can itself, transmitted its vibration to the brake booster, which I could feel in the gas pedal. In my case, the gas and brake pedal are mounted on an adjustable pedal assembly. I think by mounting the can on the far end of the bracket amplifies the vibration due to a longer lever arm. (Just my guess)?
So I've read through a bunch of this thread trying to learn what's going on. I've never even heard of a catch can, pardon my ignorance. Is this something recommended or just personal preference? I try to maintain vehicles as well as I can. Thanks for any help.
The problem is related to crankcase ventilation and how the vapors are collected by the air intake system and burned and direct injected motors like those used in the new GM trucks.
In a non-direct injected engine, the fuel injectors direct their gas flow directly into the air stream at the top in the intake valves. In the air stream at that point, is a small amount of collected oil vapors from the engines crankcase. The gas from the injectors effectively 'washes' the intake value of any oil and the valve remains clean.
In direct injection motors, the injector injects gas directly into the combustion chamber, bypassing the intake valve. Oil vapor, however is still introduced into the intake air stream via the crack case venting system. The oil in the intake air stream begins to collect on the intake valves and hardens over time. (There are a number of you tube videos that show the mess this creates on the valves).
Oil catch cans try to remove as much of the oil as possible from the crank case vapor, therefore leaving the intake valves clean or cleaner!
Ryan,
It's definitely not imagined. I pay attention to every squeak, noise, bump etc. in this truck and the vibration in the pedal is definitely more noticeable than it ever was. I always felt a slight vibration before but it was very faint...so faint I didn't think I had the problem people were describing on this forum. But now after the catch can install, it's definitely more pronounced and I understand what others have been feeling and complaining about on their stock trucks.
My can is already mounted as far back (or toward the cab of the pickup) as possible on the bracket. I did this to provide easier access to the oil cap for oil changes. At any rate, the computer isn't throwing any codes and the engine and exhaust sound fine. As long as nothing damaging is taking place I can live with what I feel in the pedal. I'm just hoping it's not something bad that's causing damage over time that will eventually show up as a big problem or repair.
WOW. Thanks for the help. I guess I need to look into one. Do they sell them kit specific to these trucks? If not, what setup is recommended?
I've been trying to respond with details to your question, but for some reason the post doesn't go. PM fails too. I'm going to try to send it in multiple small posts:
RX does, but it's not obvious when you order the kit. When I ordered mine, they did not list the 2014 Sierra in the drop down. Others suggested picking something similar from the drop down. I believe I picked Camero. Then when you advance to the next page, there is a place where you tell them the exact application. You can also select the color of the can. I selected black as they didn't list Sonoma Red.
Edited by JimmyVal
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 452 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
