Photo post attempt #1
EDIT: Sweet it worked. Here are the best photos I took during the install. You can see how I used a hose clamp to connect the hose under the throttle body. I did the same thing at the other connection on the top side of the engine.
Edited by Silverado-Hareek
Looks nice and clean! I see you also have the 5.3, that clamp from the crankcase into the can was a pain in the you know what to tighten with my intake still on!
Edited by bladz1454
I replaced the standard fuel line (50 PSI) with tranny line (175 PSI) and cleaned up the hoses paths... I just want to make something now to stop the hoses from all touching each other at the bend.
Looks nice and clean! I see you also have the 5.3, that clamp from the crankcase into the can was a pain in the you know what yo tighten with my intake still on!
Thanks! Yeah it's a 5.3. Removing the airbox and tube between the throttle body and filter box is the way to go for sure. There's really no other way to access the crankcase nozzle.
I didn't get a picture of the drain tube from the can but I ran it down into the wheel well area of the driver side front tire so any residual oil in the tube that doesn't get captured in a drain pan will just drip on the ground and not in the engine bay. It's raining today but I'll try to take some more pictures of this soon and post them.
Ryan,
I don't think it's all in their head. After I installed the RX can in my truck, there was a noticeable vibration in the gas peddle at certain RPM's. My wife felt the vibrations too when she drove the truck. Believe me it's not imagined.
What I did to solve the problem is to move the RX can as far back as I could in the slots on the bracket that mounts the can to the brake booster. I had originally mounted the can forward (toward the front of the truck), to allow easier access to the oil dip stick. Once I moved the can back (towards the firewall), the vibration went away.
I think the check valve on the can, which is mounted close to the can itself, transmitted its vibration to the brake booster, which I could feel in the gas pedal. In my case, the gas and brake pedal are mounted on an adjustable pedal assembly. I think by mounting the can on the far end of the bracket amplifies the vibration due to a longer lever arm. (Just my guess)?
I read this a few days back and the light bulb went off....I have a vibration in my gas pedal that is extremely pronounced between 1500 and 1750 RPM's and I couldn't for the life of me figure it out. (I'm slow) I have my can mounted to the brake booster bolt like many have done so I figured I would try and see if I could alleviate the vib.
I didn't want to move the can yet for no other reason than I couldn't find a good location to reuse the bracket from RX and I didn't have anything laying around to make my own so I decided I would just try and dampen the contact point between the can and the mounting bracket.
I took a small piece of 3/4 radiator hose and cut a small piece off and then cut it in half length wise 180 degrees from each other making two small pieces. Then just drilled a couple holes in each piece for the bolts (I needed longer bolts to mount the can with the extra thickness) to pass through.
I put one piece between the bolt heads and mounting bracket and the other between the mounting bracket and can itself.
I drove about 20 miles this a.m. with most of it interstate, where I felt the vibes the most, and what do ya know....Fixed! No more vibes in the pedal at all. Thank you JimmyVal for posting that, otherwise I might not have ever thought of that being the issue. Hope this helps someone.
Edited by Newm
I drove about 20 miles this a.m. with most of it interstate, where I felt the vibes the most, and what do ya know....Fixed! No more vibes in the pedal at all. Thank you JimmyVal for posting that otherwise I might not have ever thought of that being the issue. Hope this helps someone.
Wow, that's good news and a really clever fix. I think I'll try it on my truck as soon as it warms up a bit. I'm glad I was able to help.
Was it a super high speed vibration? Mine started yesterday and didn't think about the can until I saw this. I switched to stainless bolts and didn't have shorter ones, so I already have room to try this.
Yeah.....it's a very high frequency vibration, almost a hum that was most noticeable between 1500 and 1750 RPMs.
Drove another 40 miles or so tonight and it is just about completely gone. I would put it at 90-95% better. If someone didn't know to look for it I doubt they would notice.
Edited by Newm
This is awesome man thanks for sharing! I will probably try this if the vibration gets annoying enough that I can't stand it anymore. All and all though the truck is running great with the can. I'm using "trip b" on my DIC to monitor the miles on the can so I know when to drain it. I'm at about 375 now and plan to drain at 500 for an initial reading. I should be able to expand the drain intervals out from there.
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
