I had a catch can on my 2011 6.2L. After catching a decent amount of oil in a small amount of time I'll never run a new engine without one.
Mike norris posted this on FB this morning. They are pumping them out
Ryan
They are a big seller and have been in the sports car market (vettes and camaros)
Ryan
Here's what I did with my Elite Engineering can (that's CC-C7Black-Nickel "Good" - Elite Engineering Catch Can - 2014+ Corvette Stingray) for those looking for ideas:
Used the supplied hoses and mounting bracket--everything needed was in the box. Literally a 5 minute install, works very well. Very easy to unscrew and empty.
Edited by Jon A
Well tried installing my rx can today. Didn't work I don't have the plug on the top of the throttle body :(
Only the 6.2 has the intake manifold vacuum port in this location. See my post #153 on page 11 of this thread for the 5.3 location. See post #21 on page 2 of this thread for V6 installation locations.
Ok how do I get the plug off under the throttle body? I pulled pry alittle too hard and I'm pretty sure I broke it in half. I also don't have a fitting that will snap back on so now I'm pry screwed.
It's a pain to get off. I couldn't do it but my brother in law managed to get it off. You need hose clamps to hold the new hose back on. The RX install video fails to address this. If you don't care about preserving the factory hose you could probably cut it and reuse the snap lock fittings but I wanted to be able to return it to stock if I needed to so I used hose clamps to hold the new hose in place.
Edited by Silverado-Hareek
That stock hose should have snap on clips that you need to compress before you pull off.
Ya I see that now it's broke now too the stealership too order parts.
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
