Do we need to be worried about blowing out any gaskets/seals by disrupting the PCV system with an oil catch can? According this video on a Ram that was posted in another thread here on the forum, the guy in the video installed a catch can because of the oil blow by problems on PCV systems and he said it ended up disrupting the system to the point that the oil pan gasket failed and he developed a leak. He has since removed the can and returned everything to stock.
Fast forward to the 2:00 minute mark:
EDIT: In doing some more research it seems the issue this guy experienced is back pressure into the crank case caused by turbo charged systems on deceleration (I don't fully understand how that happens but that's what I've read), which the RX can prevents this with the check valve. I'm guessing this guy had a cheaper can without a check valve and that back pressure on the turbo charged EcoDiesel eventually blew the seals out.
Edited by Silverado-Hareek
That seemed to be a case in a turbocharged engine with a bunch of boost. The catch can must have been installed without a one-way valve, one-way valve installed backward, or the one-way valve was allowed to remain open. The result is the crankcase is pressurized as much as the turbocharger provides and creating seal problem.
This is a problem related to either a mistake in installation or component failure. Adding a catch can by its own doesn't create the aforementioned problem.
Great thank you for this clarification!
The engine will ultimately breath better and rings will seal better with the Oil separator.
RT
Edited by 07Softail
On the Vortecs, there is a nice large area on the alternator/power steering pump mounting bracket with two pre-threaded holes. It is a perfect place to mount the catch can. The Ecotecs do not have this, but they should have an empty threaded boss in the head that could be used..
Front of the LH head is where I mounted my Elite. Thanks for the tip Rick! I wanted to use both mounting holes in the head but the plastic line between the vacuum pump & brake booster was in the way so I used the upper bolt hole in the head with the lower hole of the bracket. It looks tight in the photo but there is plenty of room to unscrew the bowl.
Edited by Digger3
I thought I heard the guy mention it was from the tube size in the catch can being to small. Probably a more standard 3/8" size like the RX for out motor when that boosted motor would need a larger 1/2" or something.
Anyone know what GM calls the quick connect tube that goes from the valley cover to the intake on a 6.2L. Its the one piece tube with fittings on both ends that you remove for the catch can install. I have a Rx installed but my dog chewed it up and I want to order a spare incase in need to restorte to stock some day. I can't seem to find it on any of the parts sites. Its the lower one not the two topside PCV tubes. Thanks!
I think it's just called "PCV Hose." When I ordered it from the dealer the guy said there were 3 PCV hoses, one dirty one from the crank case to the valley cover and 2 clean side hoses. I told him the dirty one and he pulled a diagram up on his screen to confirm the part and the order was right. Unfortunately I returned it so I don't have the paperwork with me but I'm pretty sure it was just called a "PCV hose."
Thanks! If you come across a part number let me know.
My parts guy found it. Pricey freakin tube.
Edited by sugarjohnson
Just wondering how well your can's working for you on your 6.2. I ordered mine about 2 weeks ago, should arrive any day now.
Does anybody know if I am going to have a problem with my can if that moisture that I cant in it freezes in the winter time? That could be an issue couldn't it?
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
