I want to order mine. Is the RX catch can/ single check valve the correct one? description says its for 2010-2014 camaros v6-v8
That is it
Ryan
That's the same one I'm running. Works great. Catches a LOT of gunk, especially in cold weather. I empty mine about every 2K miles.
Rx's clean side separator isn't the greatest though. The adhesive attachment from the oil filler cap to the can on top is weak. I sent mine back because it fell apart in my hand when I tried to install it. When it came back re-glued, the same thing happened again. I guess when you glue a flexible material to a rigid one with no other mechanical fastening, that's what happens. I think I'll see if I can figure out a better way of attachment. Maybe a metal collar (like a big washer) on top of the flexible lip, screwed through the rubber to the cap. I hate to have a $100 part sitting there unusable.
Installed a JEGS catch can today.
Why does the second line seem to be heading away from the engine under the brake master cylinder?
If you look close at the edge of the picture it appears to be running along the edge of the engine bay and back toward the front of the engine. Guessing this is a 6.2L engine.
5.3. Plumbed from under throttle body, along wiring harness, comes in to can on driver side of fender well, then out and over to the intake. I tried to keep the bends as gradual and smooth as possible, part of the reason I have a lot of line laying there
Awesome yeah I see it now I didn't look closely enough at the left side of the picture. Is that salt/chemicals from the roads all in your engine bay?
I've put this off too long. Ordering my RX can right now. Also looking into a BG cleaning. Coming up on 15000 miles.
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 743 Guests (See full list)
