I am new to the board, have a 2014 Sierra SLT with just 1k miles. Have been driving very conservative while breaking things in, for the most part.
Today though, I was driving uphill and decided to put some foot into it, and noticed that coming out of 2nd gear, the shift to 3rd felt like the tranny was slipping before engaging in 3rd (at least that's how I can describe it, even though its automatic). I tried it two other times today (again, on the uphill, say 5-6% grade) and it is repeatable. I think this is occurring about 30mph or so (I'd have to confirm). On lesser grades or the flat, I don't experience this. I have a 3.08 axle ratio.
Is this a defect? Has anyone else seen this?
Any insight appreciated.
Welcome aboard! I have not experienced that as of yet. I've taken mine up some steep grades. Mines a 4x4 with a 3.42 rear end in it with 4k on the clock. I'm wondering if this is all part of the transmission learning your driving style?????
Mike
Maybe that slip is from the tire? I do notice that these trucks are very easy to break loose. Prime example of my smokey burnout at my warehouse last night.
Mine started getting better at around 1,200 miles. Only 2K now... hope it continues to "learn" something new! I hate the trans in these trucks..
It could be something to do with the trans 'learning' mode, as suggested (I hope), but definitely not the tires breaking loose. Has more to do with the uphill grade, than just pure acceleration, it seems. Not sure why it would be the 2nd-3rd gear shift only, and not any others. I guess this is one I'll pose to the dealer on the next service interval. Thanks for the welcome guys (appreciate the comments)!
icetime,
Congratulations and welcome to the forum! Just wanted to stop by and let you know that GM Customer Care is here on the forum and happy to assist if you ever have any general questions or concerns about GM products.
Safe travels,
Jennifer T.
GM Customer Care
Good to know GM is monitoring for issues here. If I run into some enduring issue, it's good to know that someone from GM is 'listening'. Thanks again for the welcome.
I have the same axle ratio as you and have not experienced that at all. All shifts are crisp and firm, especially when I give it some throttle. I would definitely take it to the dealer.
I would wait 5,000 miles before I mentioned anything about the transmission. I'm sure it's just learning. Drive it like you normally drive during this period or it will have to relearn again.
Thanks everyone. I will wait and see how the tranny learning mode goes based on your comments here. Good to have the support system here.
I noticed drivability issues like you describe when test driving 3.08's, none with the 3.42's. There is also an ECM update that specifically addresses shifting and drivability. The dealer applied it to my truck even though I was having no problems because my VIN fit the range of those affected according to GM. Suggest visiting your dealer and telling them you'd like an ECM update for drivability.
BTW, there is also a newer ECM update for the AFM. Both updates can be done at the same time, takes about an hour. Good luck.
  • 3 years later...
I have a 2016 and it has done that since the 3rd day I owned it to current. That's been since 7-1-2016 and it doesn't get better with more miles. I have 24,500 and it still does it and I have piles of paperwork from the dealer and I keep being told it's normal. This is my first vehicle I've bought new and it's a nightmare so far. I have 30 years in the automotive field as a tech. To me it's not normal along with the hitching under a load grade or no grade. It hitches like you have plug wires off. Another issue that I'm told has to done at GMs level do to it being in the programming. Have had open reports with GM and I was told they were working on it. Hope they come up with something fast for the transmission issue. I'm going to one and done if not.
You might also be mistaking the pause during an upshift for slip too? The 6 speed in these trucks really reminds me of the way my old Duramax with the Allison 5 speed shifted. There is a fuel cut I believe, tuned in that reduces power during the shift to prevent transmission damage. It can feel odd especially up going up hill when it shifts, and will send you toward the steering wheel during a shift if you aren't used to it. The Duramax would bounce your face off the steering wheel between WOT shifts.
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
    • Well one of our most reliable vehicles was sold yesterday. The first and only I gave for free to a grandkid. If they got skin in the game they take care of it. My wife bought new. Five years later my daughter got it to use. We got it back and gave it to our grandson after graduation. He did zero maintenance just oil changes. When the AC quit he drove his mother’s car rather than get it fixed. Instead he just bought a beater and sold the Elantra.
    • I usually do as well or better than the sticker for mileage. Usually better going west than east. North then South. Wind makes a difference. I’m not usually a conspiracy theorist. But it did dawn on me I’m going by the vehicle calculation. Now that would be interesting.
