Need some suggestions on what else I need for my all terrain.. Going for the black look. Any helpful ideas ? I have the power step rails
If you want it all black, try plastidip ping the chrome on your mirrors, handles, and grille. That way if you don't like it then you can wipe it off. Or if you do like it, you can decide to keep it or replace with parts that are actually painted
Great idea! Just curious how to take the plastic dip off it I don't like it ?
Pretty sure you can just rub it off. My neighbor sprayed his emblems on his explorer and used a sock to wipe off the excess (which was quite a bit cause he didn't tape off the emblems at all since he was using plastidip he didn't feel the need to try to cover any surrounding areas) I've never used it myself. But I plan on doing it soon. I need to paint this:
Everything chrome or aluminum in those pics (minus the bumper itself) will be painted black to blend in. As you can tell I'm working on adding aftermarket standalone projectors to my fogs so that I can put a brighter HID bulb without blinding oncoming drivers
Plasti Dip peels right off. I actually messed up the 1st time I did it (too much tape caused the plasti dip to peel off when I tried to remove it) and I had to peel everything off & do it again. Happened with the front & back. Lol.
1st attempt (too much tape)
2nd attempt (much less tape & no paper)
On the 1st attempt, I was trying to spray it without getting a drop on the chrome or grille in general. Would've came out perfect if I didn't tuck the tape in between the parts where the red & chrome meet because of pure paranoia. 2nd attempt could've been better, but I was tired & aggravated. Did this at 3 in the morning. Lol. I'm happy with the results though.
Edited by Thaheavyone
^^^Plasti-dip actually cuts itself when sprayed in lights coats. I did the same thing on my F150, lol. I thought more tape was better...plast-dip is certainly a case of "less is more".
Make sure you apply many layers of Plasti Dip though, it can be a b**** to remove if you only do a couple coats.
Well finally had some days off and I was able to clay bar and wax the truck now that it has warmed up. I bought my truck in November of 2013 and I don't know what kind of sealer they used to seal the paint from the factory but it seemed that it did not last very long. When it would rain the water would not bead up on 80% of the surfaces. Does anyone here know what they use to seal the paint / clear coat if anything at all?
It took me about 5 hours total to wash, clay bar, wax and clean the entire interior. It looked amazing and then this morning it stormed like crazy (Houston, TX). Anyways here some pictures, not the best as they were taken with my iphone 4s and it was very cloudy yesterday. Mods are in signature.
Also towed my Dad's 1970 Camaro and the truck pulled great, no complaints here.
Bought new last Friday. Summit white all terrain package SLT. Added Line-X premium black bedliner andToyo Open Country M/T 33/12.50 r20. Rough Country 2.5in level in the front and 1 inch block in back. WeatherTech digital cut mats on the way and it's getting 15% tint on front today. Removed air valence on front and mud flaps in front of rear tires.
Rubs slightly at full lock, but I think I can do some very minor trimming to fix this. Fits in garage by about 1cm ha
My Silverado had a baby. I'm very happy and excited. :)
Sent from my iPad using Tapatalk HD
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 2,351 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
