Black LTZ w/cocoa dune. I love it.
Level kit on it and I am pretty much done modding. Might replace bulbs with more luminous ones.
My only gripe: Side mirrors don't fold out when I put it in reverse. Or am I missing something?
Don't tease us like that and not post pics friend.
Love the color matching… Plasti dip?
Factory painted GM replacements.
Edited by LTZTom
Looks Great! Are the calipers painted or snap on covers?
Thanks!!
They're bolt on covers. A really ingenious method of attaching them too. Metal clips slide over the ends of each caliper and the covers have threaded studs at each end that go into slots on the clips and then the nut is tightened to hold them in place. I got'em HERE.
fold out or down? If down, you have to go set that
Sent from Tapashit
Fold out I'm guessing that's a setting I haven't found
Only time the fold in/out is when you push the button or hold the key fob lock/unlock button down for a few seconds
Sent from Tapashit
2.5 lift leveling kit with rear blocks from rough country. Next will be exhaust, and after I tear up these tires, bigger tires. However, overall needs nothing but I want to put more into it all the time.post-130309-0-30408600-1401493828_thumb.jpg
2014 SLE, nav, spray in liner.
As I picked her up last sat, went back wed-fri to address frame rust, and seat. Seat still moves, and they did a halfassed job on the rust. I'll do it myself!
a3e08a372685870ef4bc814f62d03196_zpsa6af
Mounted the rack and toolbox today
883C2401-C402-48DC-A309-B6CBB37DC7EE_zps
E1FBA5C1-72B3-445F-809B-DBB1F66A61EC_zps
I just drove my 6.2 with 3.73 rear end from Ohio to Myrtle beach. I can't believe how quiet this truck is. I found myself going about 85 on numerous occasions without even knowing it. I averaged 19.6 MPG. That is also driving through the mountain in WV. So much better than what I got on my Raptor 2 years ago and it's faster. I just ordered a BDS 4 inch lift, Fuel wheels and 295/60r/20 Toyo Open Country AT2's. Can't wait to get home and put it on.
There goes the quiet ride and gas mileage lol.
Sent from my SCH-I545 using Tapatalk
  • Like 4
Yep, been there done that!
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,096 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
