10k!
Mine turned to 11,000 as I pulled into work this morning. Sucks, I've only had it 3 months. [emoji23]
From the other night when I installed my VLEDs! There was a heavy mist/fog that made for some pretty cool picture opportunities!
I was thinking bout doing that set up as well with the light bars. How does it look with both light bars? Is it worth it ? Did u make a bracket for behind the grill ? And how did you rig it up in ur truck ?
4F4F8A75-6BF9-4507-9F8A-BF500CD47F12_zps
B054DC8E-DD7A-468E-B52C-887677FC4C07_zps
Check this out
http://www.gm-trucks.com/forums/index.php?/topic/155567-LED-Front-Light-Bars-%26-Pods/page__view__findpost__p__1541425
That's a ton of miles for 3 months! Then again I hit 4k and I have had mine since September.
Agree, and high mileage vs. short term duration of ownership seems to be a trend here among many. I suppose many use their trucks for work including commuting which I can equally appreciate.
I've owned my K1500 since Dec 2013 and only have 7k miles on it. (11 months).
Edited by Rewillia
ahh i see you used some plasti-dip like me. RCX lift? I'm planning on getting that too
Yes sir, your truck looks good. Definitely throw a leveling kit on it. I used rough country's 2.5" kit but without the .5" strut spacer. I wanted to maintain some rake for hauling/towing
Live in North Dakota for work, from Arkansas. Bought my truck in Arkansas in September and had 1,200 miles on it before I left and made the 1,300 mile trip back to ND. Then went home for Thanksgiving. Plus I drive it at work. I figure it'll have 100,000 on it in 2-3 years and I'll trade it off. Not keeping another Silverado past 100k after keeping my 2008 to 132,000 and spending $$$ keeping it going. I'm hard on stuff, so I gotta have warranty lol.
Always trying to keep things updated. RECON tails, I don't think their pictures do them justice on the website so I am sharing my picture with you which gives better perspective with the whole truck in view. That is an Anzo 3rd brake light. No offense to Anzo but I will replace it when RECON releases their version so I match. The Anzo is also well made and had no problems installing either. Hope you all like them as much as I do.
Edited by tstehle
  • Like 6
Always trying to keep things updated. RECON tails, I don't think their pictures do them justice on the website so I am sharing my picture with you which gives better perspective with the whole truck in view. That is an Anzo 3rd brake light. No offense to Anze but I will replace it when RECON releases their version so I match. The Anzo is also well made and had no problems installing either. Hope you all like them as much as I do.
I really wish RECON would've done this exact style for Sierras. I would've bought them right away. The ones now are just eh.
I can't wait for someone to try them on their Sierra. I didn't like the ones for the Silverado until I saw them in person on a truck at SEMA.
Did the Anzo light sit in the opening flush? Also did you have to cut the factory plug also?
The Anzo fit exactly like the OEM nice and flush. I cut the plug off the back of the factory light so I am able to plug right into the harness. The good news is GM left enough wire to be able to work with and if i need to go back I can do that also.
Got mine February 17th & just turned 3375 miles!
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 1,640 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
