Here is my 2016 Iridium Denali, 6.2L, 2wheel drive truck completed (for now) with all the updates.
Chrome handles and mirror caps replaced and painted Iridium, chrome window trim replaced with black, new Bakflip VP Tonneau, chrome door trim replaced with black, chrome Denali emblems (3) replaced with black (Ewing dealership did a great job), 6.2L tailgate badge (where Sierra was) from Emblempros, black GMC grill and tailgate emblems from American Brothers Design, black lug nuts and wheel locks by McGard (84640), GMC OEM Black gloss 22" wheels, Michelin Premier LTX 285/45 22 tires, black center caps from a local wheel shop, Black Bear Tune, GM Boral Exhaust Cat Back System, AirAid Intake (just tube), and Amp Research Power Steps.
Before
After
Looks tight!! How are you liking the bed cover? Been going back and forth on if I want one. I like the look of yours...
Sent From My Galaxy S6 Edge+
Thanks!! I had GMC's tri-fold cover for about two years on my 2014 (which I moved over to this truck before I bought the BakFlip) which leaked and didn't sit flush. The BakFlip VP is a much better cover IMO. Love the look and the functionality, much easier to use. I don't have to go to both sides to unlock it, I can sit on it if I want, it folds up so I have full access to the bed, and it comes with a drain system. It hasn't leaked "yet" with all the rain we have been getting here in Texas.
Yeah, this rain has been nuts! Good to know it's holding up. You anywhere around Austin?
No, DFW area. Heard you guys got almost 10". We got around 4.5.
In some areas yeah, my area was close to your totals, maybe closet to 5.5...
Considered painting your tailgate handle?? Then you'd match all the way around? [emoji6]
I've been thinking about doing painted handles and caps on mine, love my painted tailgate handle, that black bugged me for some reason lol.
Before
After
looks good , any problems with lug nuts , do they fit right ?????
Edited by tahoe08
Before
After
Looks awesome!
So I just added a 2.5 Rough country level w/ blocks on some 285/75/18 Toyo ATs on my stock wheels.
Edited by Horner21
  • Like 4
Where did you get the stainless strips for the steps? Edited by blwright
Before
After
Looks really nice!
3dceb3d01a186db810b5335b69f9320e.jpggot a new chrome 48 inch sticker
  • Like 4
Thank you and yes, they fit perfect.
Off realtrucks.com: https://www.realtruck.com/amp-research-powerstep-stainless-steel-trim-strips/
They are frustrating to put on or at least for me. Hard to get started then even harder to slide on with your hands. I finally used a rubber mallet and tapped until they were all the way on.
Edit: I thought about taking them off but they were such a pain in the butt to put on. I'm just going to leave them for now.
Edited by Bigham16
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
