just something to look at
before anyone comments on the racer being on jack stands while on the trailer, the car was in the local parade which started and ended near the garage where it is kept and never traveled over 5mph. We are a new team at my college and wanted to show off the car as much as we could since we couldn't drive it in the parade
On 2/21/2018 at 3:07 PM, jimmyboy8301 said:
09bacb9888aa7e8b097f61a0b1a6a768.jpgFINALLY washes it
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Man I absolutely LOVE what you've done with this. I just purchased a 2018 identical to your 2017 and was looking at what direction I should take it. The direction you went is awesome! I am not an Instagramer (w.smith203) but created an account to give you a follow so I could see it from more angles. Any chance I can get an approval or can you post more picture angles here? Thanks man and keep up the killer work!
I’ll request you. I don’t accept accounts with no followers or common user id’s, but now that i know who you are I’ll accept it lol. Thanks!
4.5" Zone
4.5" Zone
Thanks man. You and I are in the same line of work so i try to minimize my digital footprint. In 2018 that's virtually impossible lol. It also doesn't help that I have no clue what the hell I am doing on Instagram.
Edited by Boris.d.Blade
lol i hear ya bro! Be safe!
4.5" Zone
New wheels and rubber today. 20x9 with 275/55/20 Sumitomo Encounter AT's.
Edited by c.schill
My baaaad!
Didn't realize I had already posted in this thread.
2014 Sierra AT ...
4.5" BDS lift
305/55/20 Nitto Grapplers
20x12.5 "Buck" XD wheels
and lots of other goodies ....
Wheel center matched to body color of truck.
Edited by AGMthing
2" front and 3" rear blocks.  Didn't like the level with towing our boat.  Kinda looked like I was huntin' coons.
Edit: Brother swears I did 2.5" front
Edited by Downsea
Love the black with the silver
Thanks! I have always been partial to that combination. Made another addition today as well. Clearance find at Home Depot for $100. MlONCpG.jpgYM43MHc.jpg
Edited by c.schill
Here's a shot of my new to me 2016 LTZ+ Z71 2lz. Stock for now, but I'm really enjoying this pickup.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,803 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
