Bought a 2018 Denali a few months back.  Love the truck, hate the chrome so have been doing some work over the last few months de-chroming her.  After having the front end color matched, this weekend i just finished the headlights.  Pulled them and painted all the internal chrome parts satin black and installed diode dynamic switchback led's.
Welcome to the site, congratulations on the truck, like your pup!!!
Thanks man!  We are happy to be here.  She is a water dog for sure so I need to get seat covers next.
You are very welcome, 2 Alaskan huskies, and 2 Shiloh's are our "water" dogs.
Front end looks great! How were those switchbacks for install? I've been looking at doing that install on my truck.
Oh man that looks beautiful! I want to do the same exact thing to my Denali. But mines black. How did you do your grill?
Thanks!  The switchback install was easy, hard part was taking apart the headlights.  The old rubber butyl adhesive was nice cause it became very pliable under heat.  This permaseal stuff just gets brittle and cracks off.  Still used a head gun to be able to work it but it took about 4 hours per headlight to get them apart.  Only thing I don't like about the diode dynamic kits (this is my 3rd switchback install i've done on my vehicles) are electrical connectors they supply.  They are suspect at best so I just soldered the wires direct into the factory harness.
The grill is actually 5 separate pieces, the emblem, the mesh (3 pieces) and the outside trim.  So I just took it to a local painter and had the mesh done in gloss black and the outside trim and emblem edge color matched to the truck.
Yea that's usually the hardest part is splitting them apart. I had done my Porsche headlights a few years ago to convert to projectors and HIDs, I was always worried about moisture after the fact
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,015 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
