That's freakin' amazing! Looks great man.
Very clean setup you have. Like it a lot. What kind of setup?
Thank you! It's a 2 inch RC front level, and 275/65/20 GY duratracs.
Nice. I have the 2 inch RC on my christmas list hoping santa will come through :fingersx: . I was thinking of keeping the stock tire size in the Duratracs, but wonder if it will look a lil weird not having as much tire. Did you put that tire size on just to fill wheel well more?
Would prob look a little weird, I'll find a picture in a minute when I had stock tires on for a little bit. I just wanted the biggest tire I could fit, for looks mainly.
^ Here you go.. This is before the tires and before I replaced all the chrome.. God this reminds me how much I hated all the chrome lol!
Edited by gmtech117
2014 6.2L LTZ Silverado
SVM Mobility wheelchair conversion
Aviet electronic hand control conversion
20" Black wheels/wide tires
Cowl induction hood
Borla Atak Exhaust.
Racing harness for my wheelchair because not even quadriplegia is going to stop me.
Sweet truck brother [emoji106] [emoji106]
Awesome Thanks! its not nearly as bad as I thought but still might look a touch small. Those duratracs sure make a big difference in look by them selves. any way thanks again looks great!
What did you do to get rid of the chrome?
I removed the chrome door moldings, replaced the chrome handles with painted ones, replaced the chrome window trim with the standard black ones, and wrapped the chrome grill inserts with vinyl
I see. It is quite mind boggling how build specs do not allow a potential customers to choose "chrome" or "no chrome".
And GM automatically adds chrome as standard for any model other than the base.
Excluding the option for a "Sport Appearance Package" for Silverado (only black or white), and "All Terrain Package" for Sierra (black, silver, white and red)...
Did you do all of the swaps yourself, or was it done by the dealer as a part of the purchase terms by you?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
