Traded in my 2014 this week and got a pic from my buddy at the dealership of my new 2015 CC LT Z71 today!
Here she is!
They moved my brand new tires over and leveled it for me.
FCBC4F90-3306-4009-B659-F53C69A213AB_1.j
Here she is!
Why did you trade? Looks to be pretty much the same truck. Were you having problems with the old one? Were you able to take off the grill guard and steps for your new one? Still love those wheels, going to be nice when I put a larger tire and small level on mine when the stockers wear out.
Tyler
Tyler
My wife and I both got new cars. No problems with mine, just got a new one. I put quite a few miles on it this year with mountain bike races I was driving to throughout the summer...
I was able to keep the running boards, grill guard and rubber bed mat. He told me to take off anything I wanted to keep since it wouldn't add to the value of the trade at all. He also knew I just bought those new tires, and since he was a buddy of mine he helped me get them put on the new truck.
So that is the truck as it sits right now with a 2" level and 275/70/18 BFG KO2's
I'll post pics as i get the grill guard and running boards on. And I should be getting a camper shell in a couple of months for it as well.
Edited by tyrich88
2" level on the front? No problems/rubbing with the 275/65's? I am looking at this setup for myself.
On ocassion it rubs the carpet liner on full lock turns. Not a big issue and pulling them back some would take care of it. Nothing important rubs tho. Clears sway bar fine and control arms etc no problems.
My brother ended up trading his 6 MO old 15 Colorado on a Silverado yesterday. The Colorado was perfect but too small for him...
Sent from my SM-G920V using Tapatalk
Don't know who's this is but it sure is purdy:)
That's beautiful
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,307 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
