Nice!! Looks like a few new members have joined recently...Take a look at the new 4"cst lift for 4wd I'm very happy so far
Sent from my Nexus 6P using Tapatalk
My 2017 Silverado LTZ
Wow thats a nice silvy
  • Like 3
I'm digging the rear badging, where'd you get those??
Hey check out @maineventemblems on instagram
Whats size tires and rim? How big of a leveling kit? Looks good!
2.5 front 2 block in the rear.
20x10 with 33 tires. Minor plastic trim. Tried it without a level which is what i wanted but that did not work out so well. All good now but not a fan of level or lift.
Bought this used 2015 Silverado crew cab back in August. Overall it was in pretty good shape. Added the tonneau cover and a bed rug first and recently upgraded the wheels and tires (20x9 Fuel Dune D522s in chrome with Falken Wildpeaks). Thought about leveling it, but wasn't quite in the budget this time around, maybe next time I need tires.
Thinking about breaking up the color a bit with some accent graphics. Not sure whether to roll with some simple pinstriping or some larger vinyl graphics.
Edited by dbstomper
  • Like 3
2015 Elevation edition...
8EC9F7C9-21C2-40F5-B8ED-608ED061C966_zps
7182B6D9-1635-4FC5-94DE-DD79303F37A2_zps
Need specs.
Lift / Tires specifically.
Leveling kit and spacers completed
Edited by BNish97
Have any side shots? What rims? Offset and size...looks good
Need specs.
4.5" Zone, Fox 2.0's in the rear. Nitto Ridge Grapplers 35x12.50r20 on stock 20x9 rims.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
