New GM 22's , a fresh coat of wax and rear clearance lights
I like those!
Sent from my Nexus 6 using Tapatalk
Finally got time to try and post picture that didn't show up. Tires are 275/65/18 on 18x9 Ultra barrons. The offset is +14 I think and a 1" level.attachicon.gifIMG_12512.jpg
Nice rims! Never seen those before
2014 GMC Sierra SLT Z71 4x4. Bought it new in December of 2013. Has a 2" Rough Country front level, Corsa exhaust, K&N cold air intake, 285/65/20 Nitto Exo Grapplers, Undercover Flex bed cover, and LED tail lights. cab40207846f259859b6b50b294ba011.jpg17b83f2f6f092bf985f6f301353b10e0.jpg7f9ab7e1ee1afed39b42057247d181b8.jpg1305bc0af347900d9a858ff6307b64c1.jpg5ef7e9172f8e5fc6db314e7b4b24b6a2.jpg
  • Like 6
Nice truck.. I really like the front plate...
What's the difference between exo grapplers and ridge grapplers? They look similar in design?
hey fellas I don't wanna hijack this thread because we have some beautiful rigs here..but quickly I have a two inch level with a 1.5 zone body lift on my 2014 sierra 1500.
can I get away running 275-60-20 on 20x9 wheels with -12 offset??
Definitely. That can be run with only a level, without even having the body lift. That will easily fit without any issues whatsoever with your setup.
I have the Ridge grapplers on my Denali, I think there a little more aggressive like a hybrid between A/T and MT.
You can run 275/60R20 at stock height so you should have no problem with a level and body lift.
Damn that's a sharp truck! .. those 285s fit in there nice.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,185 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
