Insulating/Finishing garage
davidsi21
So here's what I got... I have a 20x30 stick built garage. I just finished the electrical and now I want to insulate and finish the inside. That said I'm going to use 7/16 OSB on the walls with faced bats for insulation. The question is a) will 7/16 OSB on the ceiling get all wavy when spanned 24" b) do I need faced or unfaced bats in the attic or maybe blow it in? And if I choose blow in or unfased bats do I have to run some kind of vapor barrier? I may heat and/or cool the garage if I'm working but not all the time. The attic is vented w/ gable vents and vented soffit.
IMO if your using the osb for your finish surface, pay a little bit more and get 1/2" sanded one side ply wood. It is going to be stronger, wont be nearly as wavy, and most important, when you do get water in the garage , your walls wont wick it up like the osb will.
You might want to check with your insurance company to see if they require fireproof finish material such as drywall.
Probably only if it's attached to your house.
Mark
