The Baja Designs SII lights came today. One of the bennies of living less than 100 miles from the maker.
This little light is really tiny. But incredibly bright. 2160 lumens. I fired one up with some jury rigging. Amazingly bright for such a little package. These are the "wide cornering" lights with the Fresnel lens with a wide pattern like a true fog light should have.
Edited by spurshot
No switch. I will put my relay on the fog light fuse with a fuse wire tap.
So the led comes on with the fogs? Can you turn it on seperate?
Neat way to do the installation. No wiring thru the firewall and no switches in the dash to install.
That's it ;) Anyway, LED comes with the fog, I want more lumens when I will go on the offroad.
The lights available today are incredible. I remember tooling around the California desert in a 67 VW with a 6volt system and two lights that you could hardly see past the bumper with.
Later we discovered K C Hilites. This little company was taking light airplane 12v sealed beam landing light bulbs and making housings for them to mount on off-road vehicles. 4 100 watt KC Hilites would ignite the night, but your alternator was working overtime and they died early. Wiring and switches carried full current. Wires were big gauge.
So this is one old guy that is amazed when a LED assembly with a few 1" reflectors drawing 1/4 of the current, puts out the same light as a 7" landing light.
Any pictures up close of the led bar mounted behind the grille (Silverado), I want to see the where the mounts actually bolt to the truck?
I plan on putting a 40" Double Row behind my grille but want to make sure I know exactly were to mount it before starting the project.
Anybody receive their $60 lightbar from Beijing yet?
No I haven't. I was told anywhere from 7-3 all the way to 8-1 I should have it
Do you like the 6000K do you find them to blue. im trying to decide 5 or 6000
5000k is better, I think! But it's my old kit on my 2010 Silverado.
Looks like we may have got taken. Bunch of negative feedback claiming scam on his feedback now. When I bought, he didn't have hardly anything negative. Now, he has a bunch of unhappy people it seems.
I use this switch on my current truck, using the high beam as the trigger, and will be using it on my new Denali once it comes in. Keeps everything under the hood.
http://www.autoswitch.com/as7.php
Mdmischief, where did you tap in to the high beam trigger wire? This looks like an amazingly clean way of turning the lights on. Thanks,
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
