Has anyone fit a 40" light bar behind the grill? Or is 30 inch the max that'll fit? I thought I remember reading somewhere that you can get a 40inch behind the grill.
I believe the 30" is the max but I'm sure with some cutting of the plastic sides that are behind the grill you could fit a 40" with no problem.
I have a 32" curved behind my grill
You can get a 40" to fit. I've seen straight and curved 40" bars behind the grille of these trucks. You'll just need to do some trimming to some of the plastic.
Thanks for this! I see you've got one behind your grill. Do you think mounting it behind the grill has lessened the ability of the LED bar to put light out to either side of the road up close? Like, does the beam still cover a wide area?
Here are pictures for you to compare. 1st picture is headlights only 7e8eaf2e538d214980bb781a8cceee28.jpg
2nd picture is headlights and fog lights 80221d70c6e92d568cc79ec21779aadd.jpg
My bar is spot beam only. And I always recommend it so that the most light from the bar can get through the grille. I feel like the width of the beam would be hurt by the width so I went for the spot only.
It seems much harder to find the Spot Beam only LED Bars, at least while searching Amazon. What's the name of yours?
No name. Got it on eBay for $90. I think it was from seller Online-LED-store. I'll check
Edit: I can't find the transaction on eBay nor do I see the seller. Though I know it was from eBay and I'd be willing to bet money that the seller was "Online-LED-store".
Edited by Mike1220
Or buy spot LED light bar directly from China. My brother, sister in-law, and I buy our bars from China. After years of using it, it still lights up well. No burn LED or anything.
If looking for a light bar, I intend to go with the OPT 7 ones. They're a lot cheaper than say, Rigid (Which is crazy expensive), and the OPT 7 LED bulbs and LED pod I ordered after seeing one in person look very well built. I am reading through this thread right now though, looking for switch installations... I haven't figured out where to put the switches inside the truck.
No worries! I'll do some more searching on this.
I just checked them out they do look nice and are also relatively cheap. I like that you can specifically choose Spot Beam when ordering.
I just measured the opening of the grill. Seems like it's 37 inches or so. It almost seems like you might as well get a 30 / 32 inch bar and save yourself the extra work of the 40 inch to get it to fit. Plus all the light on the 40 wouldn't be making it to the road (based on my quick measurement.)
I could be wrong.
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
