Has anyone installed the newer OSRAM type LED light bar vs CREE?
I've been looking at this: https://www.amazon.com/dp/B00ZF34KZ8/ref=cm_sw_r_cp_apa_R-vdybZS3QW4V
Sent from my Nexus 6 using Tapatalk
I actually just installed a Black Oak LED 30" single row light bar behind the grill. I chose the 5w osram option which is in between the 3w osram and 10w cree. The light bar is out of control bright. It's a combo light and the spot beam in the middle has a huge throw! That light will definitely reach out and touch someone. lol. The quality of black oak is second to none and I believe they still are offering 15% off on their sight. The osram leds are no joke. They're stupid bright273236c6b871cce0da08d8560c0cfb51.jpgb8eaf729d9bc3bf531caecba28f071b9.jpg
Edited by Abearclaw
Thanks Mike I appreciate the reply!!
I have a '17 LTZ and bought the rcx 30" curved for behind the grille but my truck apparently has the electronic flaps/louvers and the bar will not fit. Has anyone found a way to make the bar or a similar bar fit?
So you have this package? http://media.gmc.com/media/us/en/gmc/news.detail.print.html/content/Pages/news/us/en/2016/feb/0225-sierra-eAssist.html
I also have a 17 and was wondering if the rcx kit would fit with those flaps behind the grille. I didn't even know my truck had those flaps when I got it. Hopefully you come up with some why around them.
Sent from my SAMSUNG-SM-G920A using Tapatalk
I looked yesterday and they take up the whole area behind the grille
What are the dimensions of the light bar as far as depth? I know there's a little room. I just don't know if a different light bar might fit.
Reasons why I didn't buy a dodge and got the gmc for some reason gmc doesn't put those in there grill but at times with the big grill openings gmc has the amount of crap that gets in there sucks Good luck what about putting the bar under the bumper by the plate like some people have
I checked, there's literally no room. A few pieces of paper would be tight lol.
I believe the 17 GMCs have them also, ford started in 15. I don't like the bar hanging down under the bumper like that lol
Do you know what model 17 gmc has them my buddy just got one 2 weeks ago his grill is wide open like my 15 and 16
I thought all '17 Silverado and sierras had em
Can any of you guys with the '14 or '15 Z71 grille report back on how your output abd setup is
Output is only thing stopping me right now
Edited by quise2024
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
