Well ive asked a few officers ive seen around the city while workin an they said there isn't a problem so long as im not "abusing it" i.e actually driving with them off.. so idk?
An my insurance isn't bothered buy it an doesn't change anything on my stuff so..?
But im just curious as to if the sensor on the dash controls other stuff or just the head lights. cant seem to find it online.. :(
[quote name="the_canadian" post="1380533" timestamp="
I would like to disable them so they cant turn on when i drive at night if i dont want them to. I want to control whether or not they turn on by turning the knob on or off
I wasn't trying to be rude but it was about what you said here. I just don't see why it bothers you for them to come on automatically. Besides they shut off automatically too. Sorry if you took it to be rude, I was just meaning stay safe.
That was the only way i could kind of explained my self, if you go through the other posts you'll see i was having problems with explaining the situation.
My truck was built in Canada and u can't turn my lights off either it's really annoying I'd like to shut mine off too. The only way to shut them off is if I start the truck while parking brake is on.
Sent from your truck
Well once i figure it out ill pass on the info to you. Though most likely might be different cause of year if your driving an 06.
The light sensor on the dash also serves as the HVAC sunlight sensor. Also unplugging it will make it think it's night and keep the headlights on. It's designed to default to headlights on if the sensor fails.
You said the lights will turn off if you're stopped. You said you want them off while the truck is moving, at night.
I don't see why you would???
Put a kill switch right before the headlights if you want it that bad. They'll stay off whether the main switch is on or not. Should accomplish what you want without having to mess with the factory switch.
Or better yet find a location for your still/meth lab where people can't see your lights. :ninja:
Edited by kstruckcountry
I believe the lights are required at all times in certain parts of Canada if memory serves me correctly.
All parts
Sent from my HTC One S using Tapatalk
  • 3 years later...
I've read quite a few posts about putting in resistors or removing sensors and trying to make this subject way more complicated than it needs to be. I wanted to share the success I had with my truck that took less time to disable the automatic features than writing this post will take.
Simply remove the light switch panel/housing from your dash and disconnect the plugs going into the back of each switch. Take the assembly inside into some good light and take apart the headlight switch from the housing. Next take apart the switch itself being careful not to pry too deep and pop the releases (the circuit board is just under this cover). Once open you'll see a small coiled spring in one of the corners. Lift it up and it pops right out. Reassemble everything and you're done. Less than 5 minutes and your lights operate the way lights used to work....turn the switch if you want them to come on. You can still move the switch to auto if you want as well but now they will stay in the off position if that's where you want them.
  • 6 years later...
My problem with my 2008 Silverado and DRL is it dims the dash cluster to the point I can't read the speedo.  With my LTX livery and the little light control knob, I have to reach down and manually turn off DRL to see any gauges.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
