Day 1 Brand New
So I'm looking into doing some lowering on my new 2017 regular cab. I originally wanted a low 2wd street rod type of truck, but there's just those occasional winter conditions around here that make a 4x4 necessary.
I already removed the lift block in it which gets the gap up front around 6" and the rear 8.25" (was previously 9.375" with the block).
After a lot of reading I think my plan is to do 2" front using Belltech's front adjustable struts and 3" in the rear with Belltechs 2-3" shackle and shocks. I don't want to do a flip kit and such just yet as I drove the truck off the lot with 8 miles just yesterday.
Am I on the right track? My main priority is to keep it riding really well, so if there is a better way I'd probably take it.
Here are before and after with the block removed
Before
Factory Rear Block Installed
After
Factory Rear Block Removed
Id do spindles over struts if you're just doing 2" in front. Keeps alignment better
Are the 2wd spindles listed the same as 4wd? Brand preference?
I want to be sure I can go to 3 or 4 up front later on.
Sent from my SM-G930P using Tapatalk
I forgot you had 4wd. Not sure there's a 4wd spindle yet for avv arms. I guess start off with the struts
Quick tire question. With a 4/7 drop and 22's what size tire should I run to avoid most of the rubbing?
265 40 22 or 265 35 22
35 series will look a bit small though
Either way you will still have rubbing, but a lot less
What about a 20" wheel with only 3" drop up front. All the tire fitment threads I'm finding seem to cover lift kits and negative offsets.
I have a 20x10 +10mm
2017 Silverado 1500 Z71 4x4 Regular Cab Short Bed
Edited by JRoyPDX
I run a 305/45/22 on a 4/7 drop
I only rub on big dips on the road and when the wheel is in full lock
I run a 265 50 20 on my 4/7 drop
Heres my new truck just lowered it this past weekend. Its a 2/4 drop right now with knuckles in the front and an axle flip in the rear. More mods to come in the next few weeks.
This is a WT right?
I'm wondering how much taller an LT Z71 is over the regular trims.
The 4x I'm almost positive are the same height. My 2wd looked lifted when I first got it
My 2wd is at 36 7/8 up front and 40 5/8 in the rear. Not the best picture but this is how it looked with out the lowering shackles. 0907bc2fbb9581293e8879422d57988b.jpg
Sent from my SAMSUNG-SM-N920A using Tapatalk
Almost positive that is what my 4x4 CCSB is at factory as well
    Ryanwehr14
    Ryanwehr14
  • Who's Online   6 Members, 0 Anonymous, 563 Guests (See full list)
