Are the 4x strut/coil spring in front?
If so then 2wd an 4wd are the same. Just like the leafs are the same. Even for the cc trucks
I was talking about the height of different trim levels. All of The 1500 are coil. But is a 4x4 LT and a 4x4 LT Z71 the same height? Is it possible the Z71 is taller with the Ranchos?
2017 Silverado 1500 Z71 4x4 Regular Cab Short Bed
On a side note the shocks arrived. And the spindle and flip kit were shipped today. Wheels shipped today too. The excite.077a587ed585a0f651130f398e8d5b3d.jpg
I,don't think struts/shocks raise a vehicle. Just there for dampening but I'm pretty sure all the springs are the same with exception of maybe the toe max 1500
Just like the adjustable Belltech the position of the bottom spring collar could be higher.
I'm looking for some spindle info.
The 2017 4x4 has stamped steel arms and a cast steel spindle. After talking with a friend who works for Maxtrac he sent me a pair of spindle that appear to be the right shape, holes line up, etc. They do not fit though, it appears all of the tapered holes for ball joints and tie rods are too small in the aftermarket spindle.
Does anyone know of spindles known to work with 2017 4x4 with stamped steel arms? It appears maybe McGaughy, but they sell them with an upper control arm too.
The kit I bought from McGaughys came with spindles and no upper a-arms. Fit perfect with stamped steel arms, no fitment or alignment issues. I didnt use lowering struts yet but am going to in a week or so to get the front down a little more.
You have a 2017?
Yep, but I'm not spending 1200 bucks for some spindles. I talked to djm this morning and went that route
IHS upper and lower control arms are $800 shipped and they maintain camber. Also comes with a flip kit. Thats the route I am gonna go.
You have a 2017?
Yessir, I bought the 34270 Kit
That kit says no on 4x4, but what spindle is it?
I have a 2wd so I dont know what the difference would be. Might have to contact McGaughy's.
    250.3k
    Dad X MTB
    Dad X MTB
  • Who's Online   1 Member, 0 Anonymous, 311 Guests (See full list)
