9 minutes ago, 17gmclowlow said:
Sorry. Been busy. I returned the under bed notch and ordered the monster notch and front and rear tubs. Going much lower than I first wanted to
What size tires will you end up with and how low will you be going
Have not gotten that far. (About tire size) I'm going 6/10 for now since I have the suspension for it already. But maybe next year I'll bag it and be done. 6/10 on a static drop is very low but inconvenient for a daily driver. I am staying w my 22" or replicas. Just not sure what tires I'll run
Are you changing the front arms? Because if so id do the whole front setup not    less rubbing in the end
Yes I will be changing the control arms. Even now I have camber that can not be corrected. There are so many options available for these trucks.
There isnt many.  Im not saying the crappy djm or inez control arms. Im saying the twisted metalworkz arms or black top industries arms. They will change the upperarm mountand upper and lower arms because going that low your wheel will be pushed back into the fender. These arms. Use new mounts and tuck the front wheel in an extra inch
I was looking @ reklez. There's is similar to twisted metal works. But I'm leaning towards twisted. More people running them
Reklez are for 7" plus drop but they are bolt in requiring no modifications.  Twisted metal will work for any height and coilovers but you need to chop off the upper arm mounts and strut bucket and weld in the new
Just picked up the truck 30 minutes ago. Took it for a drive around the neighborhood and it rides good, I am experiencing some rubbing on the liner so I'm going to pull it back over the weekend.
Here are some bad pictures. Its supposed to be 4/7 but I think the front is to low.ecc3c9e06373b99553cb04129af2d6fd.jpg729af56b2b5388a7551dea38345ee0b0.jpg
Thats a 4/7. Looks low because your stock tires. What kit was used
Mcgaughys 34270. It rubs like crazy, even going down the road at 20mph with the smallest dip it rubs.
How many rings did you put in the front struts? And yes you lowered the truck 4" in front withba tire thats almost 32" tall. My front tires are a hair over 28"
Edited by Nasty
I didn't do the install myself. I had a reputable shop do the work so I don't know how many rings they put.
Thats something you should know. You should know everything they did
I was going to ask those questions but when I got to the shop I forgot to ask as soon as I saw the truck because it just looked so good lol. I'm going to call them right now and ask.
    520Zilla
    520Zilla
  • Who's Online   4 Members, 0 Anonymous, 561 Guests (See full list)
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
