On 2/10/2019 at 2:07 PM, Nasty said:
I have a set of inez shackles which are a bit longer than most 1" lift shackles so i think theyll clear. Thay should also lower the truck half inch if you are at 6 with a lift hanger
Have you put the Inez lift shackle in yet Brandon? I was considering it for same reason of looking a tad longer - Just want to know if it's an improvement over the Belltech and Mcg lift shackle
I havent and i dont think iam either
How come?
How come?
Im staying at the height i am now or lower. I cant get myself to lift the truck
21 minutes ago, Shibbby911 said:
I’m using the Belltech lift shackles on mine
Do they rub on the hanger? I have them too and the upper shackle bolt touches the hanger/frame - I know some guys have had this and have either left it alone or ground the hanger down a bit to allow for clearance. I spoke to Belltech and they told me to do the same thing
On 2/10/2019 at 8:39 AM, Nasty said:
Whats the part number on the trans spacer? I might need one
Belltech 6521-003
I’ve noticed it squeaking now. I’ll have to see if that’s my problem
3 hours ago, Shibbby911 said:
Both shackles are hitting
Told you. Lift shackles suck ass. I had that issue
I have a set of inez Lift shackles that are a hair longer and they should clear. If you want
Ha ya. I might have to get them I didn’t really wanna go lower in the back but the squeaking is annoying as hell ha
I can send you the inez ones tomorow to try. They are 3/8" longer than those shackles so it ahould clear. No promises though if they do clear though
I’ll let you know Next week I just ordered a choppin block chassis and had to take the girl out today ha. I gotta let the funds build back up a little lol
Im saying free. I dont recall saying anything about buying them off me
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
