Here's mine, I've had it almost 10 days. 2014 Silver Ice High Country 4wd with the 6.2 liter engine. Probably going to add a leveling kit with 285/55/20 or 295/55/20 tires, I'm on the fence about swapping out the wheels for chrome or black XD wheels. May lose the toolbox as well, my last truck was a black Z71 and it looked way better on it, and go with a trifold cover.
DHR
Sorry about the upside down pics, this one should be better...
I was able to get a lil better pic today I got the muffler deleted. No regrets-
Not great pictures but here it is :) had to reply to three topics I had started regarding this truck ha ha ha.
Rides nice and the lack of road noise is amazing!
  • Like 8
Added the Chevy 22's yesterday, going to ditch the toolbox and go with a tonneau cover, just have to figure out which one...
  • Like 8
^ something is not right about the wheels. Doesn't go well with the truck..
Edited by block8head
Wow, thanks Blockhead! I guess maybe its because they are Chevy wheels and not Cadillac wheels is why they don't go well, oh wait, it is a Chevy. Dude, seriously, everyone has their own likes/dislikes, I could pick yours apart but if you are happy with it, I'm happy with it.
  • Like 5
Here's my Crew Cab. I've added a bak flip tonneau.
I like the wheels. Nice looking truck
Enviado desde mi DROID4 mediante Tapatalk
Easy pal, i didn't say that i don't like the wheels .i love the wheels, but something in that pictures make the truck look out of place..
lol.. Carry on citizens.. :D
I love those wheels, I've been thinking of getting them and painting the black areas silver to match the truck.
This looks good. What lift and size tires are these?
post-126361-139085626823_thumb.jpg the day I got itpost-126361-139085632862_thumb.jpg now tented windows and running boards. 2014 chevy Silverado Z71 4x4 5.3. Love everything about this truck. Can't say enough about it.
Sent from my SAMSUNG-SGH-I317 using Tapatalk
    Paul8556
    Paul8556
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
