I can see the new thread title now. "Anyone else's silver truck turning red?" I paid 50k for a silver truck, got the fire recall update done and now it looks red...
Reminded me of that movie :The Jackal"
Edited by block8head
Here's mine after I had her a couple of weeks.
Since this picture I have Dipped the emblems, added C-Matched Handles & Mirror caps and TInt.
Haha that made me laugh
Sent from my Galaxy S3 using Tapatalk
This looks good. What lift and size tires are these?
Thank you :)
It is a four inch BDS lift with 275/65/ R18's which are 32.1 x 10.8 I believe. Lots of room with absolutely no rubbing.
The front tires do stick out about two inches past the fenders though which throws mud all over the truck and on the mirrors. I don't really want fender flares but may have to get them.
  • 5 weeks later...
Thought I'd throw another one in the mix.. Haven't seen her clean since day 2 hAha.
Great pics Bladz! Is that your firewood stash for the winters?? Smokehouse??
Edited by Sooperdave
Thanks Sooper, nope that firewood (it goes back about 40 feet at that height) is for maple syrup boiling :devil:
We just had our first boil this last Saturday and should blow through all that wood in the next 4-6 weeks.
Edited by bladz1454
Posted a stock pic of mine a couple months ago. Here's an updated pic with tint, BedRug, and wheels/tires.
Just picked up wheel house liners but haven't put them on yet.
Tonneau cover coming next. Then drop shackles. Then some silver paint on the front bumper.
New wheels
What kind (and size) tires do you have on your truck? It looks great!! (and did you do a leveling kit?)
Leer 550 tonneau
I put a Leer 550 tonneau cover on mine. I think it came out alright.
Edited by Coy9901
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
