Another, what do you guys think?
Those look really good! I was thinking about the same ones with the chrome strip, but after seeing yours, I don't think I would want the chrome.
I recently bought a white 2014 sierra crew cab with a black low profile tool box. I was thinking about getting the black 6 inch oval assist steps to match the tool box, but i want to see what the black steps look like on the white.
Does anyone have a photo of a white sierra with the black steps instead if the chrome?
Anyone has any tips on installing the AMP steps? the Plug & Play one, they should be here by the end of the week.
Tips on what tool to have, what to do before for any sort of preps etc.
I already have the firewall grommet punctured for other wires, there is still space for the 2 leads AMPs will use, I have also removed my OEM running boards, anything I need to keep from them? bolts and the U nuts at all?
I've never had running boards before, but my wife is 9 months pregnant and I'm thinking about getting a set so its easier for her (and the kid eventually) to climb in. My apologies if this was covered somewhere, but can someone break down the differences in materials? I would worry that aluminum would not hold up, the black running boards might scratch or chip... Am I off base? Any input or help would be appreciated.
Your concerns are exactly why we went with stainless steel ...and, they still look like new!
Does anyone know if the amp research one are lower to the ground than the ones gm offers?
Edited by Jas29
Yes they do. Much lower and in a much nicer spot for stepping
Anyone with the AMP step live in a harsh winter area? By harsh im talking long winter and or heavy snow areas (Dakotas, Minnesota, Montana, Maine, etc
I want to get them eventually but wont even waste my time if they are going to freeze up or not work in cold weather. 20 degrees or colder outside, driving on a wet road from melted snow for say 30 minutes or so, then get out and they don't open. Truck sits for a few hours and its frozen in the close position
I have a CC standard bed I would like steps to go back to the rear tires. So I can reach into the bed. My last trucks tires did that and I miss it.
I have the N-fabs bed access steps so they have the 3rd step for the bed. The steps are very sturdy and they don't cost too much. I had a set of Weston wheel to wheel steps which also have a 3rd step, but they were just 3" round tube and didn't feel as sturdy. I've banged the steps on a curb a couple times and all it did was scratch the powdercoat, didn't dent at all which the Weston tube steps would have.
The new Amp Reseach PowerStep XL steps have an additional 3-inch drop over the original PowerStep.
I wonder if these would be to low for a truck that is at stock ride height.
I would say these would be for lifted trucks. The standard PowerSteps are just the right height for stock ride height. My wife and mother are both "vertically challenged" and the regular PowerSteps are just right - my truck is stock ride height.
The regular boards are perfect IMO and several family members' opinion for one of these trucks with a 6" lift. My mom and sister are both vertically challenged. I think a powerstep XL dropping 3" lower than the standard boards would be too low to really be helpful
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
