So I just found the ones I purchased back on Amazon. $159. Tyger Auto TG-RS2C40038 RISER is the title of them.
I ordered the Tyger Star Armor that I referenced and put them on today. Very heavy duty and the finish and fitment is great. 111 pounds shipping weight lol. I will get some pics up tomorrow.
Damn!!! Sounds heavy duty. Can't wait to see them.
This is all I have right now. I will take a few installed tomorrow.
  • Like 3
Tires and wheels go on some time next week. I will clean it up and take some good pics.
  • Like 4
My 16 came with the 4 inch round gm tube steps the bend in behind the front tire. After 8 months the paint is riddled with rock chips. I have mudflaps on and hardly ever leave the pavement. This is a poor design by gm. The 6 inch rectangular steps have a plastic end cap to absorb the impact. The 4 inch round ones have nothing but exposed paint. A waste of $600. The attached picture has a little dirt but most of the spots are paint chips
Edited by ShamrockShooter
Those look nice! What did you give for em?
I had mine line-x
Appreciate it man. Paid 289 on eBay straight from Tyger. Pretty good deal I think. Edited by CWilliams
Did those attach by the body mounts or the rocker panels? They look nice. About how long was the total install time?
Sent from my Nexus 6P using Tapatalk
Each bracket mounts through the pinch weld and into the rocker panels, just like the oem steps. Took me about 1.5 hrs. to install. Definitely would have been faster with some help.
I had a piece of leftover plastic so I decided to make a couple pieces to go from the fenders to my steps to try to prevent rock chips in my doors and to keep the steps clean. I got the idea from these pieces made for Raptor steps.
5D8C8A1E-5C7A-4789-B6EC-BC05CF9D642F_zps
I'm not sure yet if I like them, but it beats having mud flaps hanging down.
B2944DDF-3BDA-44B6-AA86-2550CDE81AAA_zps
2C60F3BF-4A4F-4C74-B76C-8D1D49C47C31_zps
5552469D-9791-4D79-A932-44992C7C52F4_zps
Edited by HoosierZ
Couple more pics of different view with the ebay hooped bars. So far still working great and longer have people sliding off the seats and pinching off the leather.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 175 Guests (See full list)
