Not hard at all, they bolt into pre existing holes underneath. I installed them by myself in about an hour. I still love them! For the price, they can't be beat!
Sent from my ZTE A2017U using Tapatalk
So no drilling extra holes etc? It's a literal bolt on? Im not super handy with truck stuff, so im hoping itll be an easy project
Did you need to lift the truck to install? (tire jack,etc?)
Edited by shockedimpy
no drilling required. i was able to install mine without having to lift up the truck.
He's correct, no drilling at all. Literally 0 drilling. Don't even have to jack up the truck to install. There are 3 nuts that are welded to the body (i think thats what it is?) that are already threaded. you sit the bracket over the threaded holes, and you screw in the included bolts.
just installed the rough country nerf steps install took about 30 minutes
The frame holes in my 2016 Sierra 1500 weren't threaded. I had to put the included nut-clips through the holes, and used nuts and bolts for the bracket end on the lip. It was still a pretty easy install.
I ordered the DeeZee NXT boards last night to replace my 4" chrome GM steps. DeeZee has a 10% mail-in rebate on all their parts thru today. I went with the crew cab length boards for my double cab after seeing in pics that the double cab length boards fall a few inches short of the back of the cab. The longer boards will also help prevent some rock chips on the lower bed sides.
Post some pics once done. I am considering those to among a few others.
Tyler
Tyler
Same here, I don't really like the 4" GM OEM flat top round chrome steps. I like something wider to stand on like those 6" NXT. I'm just wondering what to do with the GM OEM boards, would they sell at a reasonable price?
Got mine from the dealer for free. My wife wanted them on the truck and argued with the sales manager till they gave in. :) They installed the 6" chrome version. I like them but have been thinking of spraying them black since I got my wheels/tires.
Some dudes have even line x'd them. Looks pretty good
Got my DeeZee NXT boards on. The crew cag length boards (86") are perfect for a double cab. Their ext/double cab boards are only 73". They are fully adjustable front-back and 1" in-out. I have them set all the way out and they stick out the exact same distance as the factory steps. I'll get some better daylight pics later.
E967BDDA-84E9-4727-81DD-DF7FFED7CDC0_zps
901170EE-053D-4BBE-85D3-DF1B3B9F8495_zps
2D16992F-5AB5-4C0B-B1D9-9405E90CEC2A_zps
81828C3B-EAE6-4B22-B454-7FB3E20366CD_zps
3BC6167C-7393-4503-BD9C-4CC7A857A231_zps
A9B29DEC-C015-42F5-A5B9-274A96EB421B_zps
looks good
Hoosier,
What was your total cost? I went to their site and mounting hardware is additional but I couldn't find that cost without going thru checkout. I assume you (we) only have three mounting brackets on our double cabs?
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
