Looking to buy a set of amp steps for my 2017 1500.  It currently only has a 2" level but I plan on lifting the truck next year so wanted to just buy them now.  Is anyone running these on a 2" level?  I'm just curious as to how low they drop down when they are in the down position.
On 10/8/2017 at 6:13 PM, SierraZ714x4 said:
Just won a set of AMP steps with plug and play off ebay for $560...... lucky day
Have you received these yet?  I have found something similar, just worried that it could be too good to be true.
Just installed a set of Havoc HS2 nerfs on my 2015 Sierra. Highly recommend them to anyone looking for a set of steps
yes i have received and installed them. 100% legit from a verified seller on ebay with 100% feedback so i trusted it. the lowest price i have seen by it now is around 1200 so i got extremely lucky with the no reserve auction.
On 10/6/2017 at 6:47 PM, spoolindawg said:
Heres the Westin HDX installed on my 17 LTZ.
Fairly easy install, would have been a lot easier if the damn brackets were labeled, didn't even use the instructions as they were not very understandable. Also had hell getting one of the bolts started, ended up being some slag inside of the bolt hole on the running board.
Not a fan of the way any boards look but couldn't justify the Amp researches, i also have a a very expensive gun and watch addiction I need to feed lol.
Those steps look great. They hug the rockers nicely.
I installed amp boards on my single cab this last weekend and love them , had to make them fit since they don't make a set for single cab
Edited by wing98
Wow.... how exactly did you manage this?
I had to move the rear mounts forward to clear the cab mount , works great had to move it 6 inches and drill new holes it puts the rear mount right where i step so works perfect
i cut the boards 44 inches
Edited by wing98
I have a Short GF who is wanting me to get a set...not a fan of any either so...i guess i will pick one that looks good.  Cheaper to get rid of the GF thou...
Nice guy.
:happysad:
2 minutes ago, Scuba78 said:
Facts are facts sir.
True.
Fact;
Running boards that are rocker mount aren't the best.
Frame mount are IMO.
:happysad:
I sort of disagree.  Both have pros and cons.  The problem with frame mount is that they require longer brackets and thus cause more stress on the frame.  Rocker mount has shorter brackets and are fine as long as the brackets are well made.  The most common type of mount is rocker panel and I've never really heard of anyone tearing off their step bars from the mount.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 815 Guests (See full list)
