Nice job I just got mine in today we'll start the install tomorrow ... Did you get all the USB plugs to work the one up front and inside the console?
Interested in hearing how it goes. Please let us know what you find out on getting all of the plugs working.
I got the console in still working on some of the plugs I got all plugs in front of console working..post-126788-0-87931500-1398633214_thumb.jpgpost-126788-0-61243800-1398633248_thumb.jpg
I really want to do this! Are those 4 part numbers everything needed? How does it attach to the dash? My dash has the little pull out cubby. Does that trim come off? How did you reconnect the plugs on the front and are there plugs inside the lift up console part too?
That is the part numbers you will need,, the pull out cobby comes out open tray one screw there and two at bottom then it we'll come out .....the front of the console will slide in the cubby hole as for the plugs I had the jump seat with the usb in the console I toke the wire harness out of my old console in pluged it to the plugs up front of the new console still working on the plugs in the new console...
Sorry, what do u mean you used the harness from old console for the new plugs in the front? Also, what plugs are in thr new lift up console?
My old console under the lid there was two usb, sd card reader, 12 volt charger, and aux port I removed that wire harness off the old console. I used that harness to plug in to the 3 USB ports on the front of the new console. Under the lid of the new console there is two usb, sd reader, aux, and 12 volt charger.
Like Wade, I was able to have my auto body install my console last week. They also removed the wiring harness from the jump seat and used it to get all of the USB/12v/110 outlets to work on the front of the new console. They were also able to get the 12v inside the storage compartment to work (it is hot with the key on only). Unfortunately, they were not able to get the SD/USB slots in the storage area to work nor the 12v on the back of the console (for rear seat pass.). I'm sure some more technical savvy individuals, or a car audio specialist, could get these to work.
It looks like Wade was able to provide you with the part numbers and I did not witness the install due to work related travel so I can't be much help...... I love the console and if you have the money to spare and some time it is well worth the upgrade!!
I'm no wiring guru but can you not tap into the other 12v to get power to the rear one? Or write the new sd to the old spot it was hooked to or where the harness you used was hooked to?
Yes, I assume that is all possible but unfortunately, I had a body shop do the work while I was traveling so I wasn't able to see the wiring setup or harness configuration. I'm sure someone with a little wiring experience could get everything to work without burning the truck down to the frame!
Good luck!!!
What were the prices through dealership, body shop? Its about $500 all together from an online store but im leery of ordering from somewhere like that (gmpartsnow.com)
Also can someone take a picture of the inside of the lid on the new console please?
Going through the dealer to buy the console will cost u more.. If your parts guy is nice he could sale it to u at wholesale ....my dealer did got the whole console for 600 ordered it on a Monday had every thing in on Thursday ..if I don't get home from work to late I'll take more pictures of the console.....also there is a wire harness that comes all ready installed on the new console ..that wire harness is pluged to the sd / 12v / usb on the back part of the console....in a truck with the console already there is a wire harness that come out of the dash and plugs to the console..trucks with out the full console dose not have the wire harness coming out of the dash...I'm working with my parts guy to find that wire harness ....so every thing can be plug and play....I'll take picture of when I get time to show everyone....if we could get someone who bought there truck with the full console to chase them wires down to se were they go in the dash that would help a lot ....
I think you should be able to use the harness already there to use the 110 and one of the 12v... then just tap the other 12v into the other and then run the usbs to a keyes wire.... those would only be a charge only and wont be able to play music from them but thats what the arm rest usbs could be used for. Then everything works
    • This video may not be the exact content for the joke thread but its a lot of laughs so here it is, I've only watched a portion of it so far but if anyone is looking for some light hearted good soap box driving action, its here. As a note in the upper left of the screen it shows the number out of 100 to refer back to any particular vehicle for comment !.    https://www.facebook.com/reel/1351928276956715
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
