23466980 shows online it will not fit my 2016 , I guess that is not correct? I tried the 23466999 and found nothing?
The 6980 was from the 2015 model so it comes with an SD card slot inside as well, but it does fit. I ended up switching my USB/aux port from inside the original fold down console with the USB/aux/SD port that came with the 6980 console, and now my apple carplay works as well.
Great .not to worried about the outlets will worry about that later Just want make sure the thing will work and look stock!
One more , looking for black , silver or grey upper trim and seems some are discontinued , they do have this but is it silver or grey or tan or what?
  • Manufacturer:GM
  • Part Number:23467112
  • Part:Upper Trim Panel
  • Part Notes:Upper trim, with 110 volt outlet, reverse tartan.
  • Never mind found the silver one
Edited by breid1983
I noticed someone of you said that you need M6 bolts (M6 X 1 I believe), but what type of bolt head would you recommend?
Amp rack with 1 jl audio 600/1 waiting on the 400/4 to fill in the other slot
Rhino lined my ported box
Painted faceplate will paint some other panels soon
what color did you use to paint interface?
UPDATE:
Parts ordered today , finally found a code for free shipping, before was looking at $190 for shipping, total cost was $625 , thanks for the thread and help, good stuff right there!
Ok someone posted a junk yard search link. I looked up a console and found LKQ/Keystone in Wayne MI close to my work. Got a near complete black console with the z71 reverse hounds tooth trim for $137 otd mint. Missing the front dash bracket and cupholder piece. Can you get the cupholder seperate? They said they would find them for me cheap. Smells like a fruity airfreshner but ill clean it.
Just the cupholder or the whole plate assembly?
Great i took a few hours today and put my junkyard console in. Your all right once you get both harnesses out, look at them you can see where to splice them together. I soldered and shrink tubed all my connections. Only thing is i am waiting on a usb cable #19303284 from the glove box usb to console USBs. Was pretty strait foward. Looks sooooooo much better the way it should have. Thanks go Slatemetal15 for the Pm help
Edited by afireinside7444
Do IT !!!!!!!!!!
I just got tracking # , it will be here Monday !
Where did you order yours from I'm looking and when I put the numbers it said part discontinued
Sent from my SM-G935V using Tapatalk
http://www.gmpartsdirect.co/
I have a 2016 It fit perfect, I ordered the wrong bracket, bottom instead of front, but with no front bracket it is solid and absolutely no shake. They wanted $190 or so for shipping, but I googled it and found code for free shipping. I also ordered a cable that was wrong, so I wasted about $30 there. I have not finished the wiring but have a 110 and a lighter socket working, all I need is one really for charging phone.
Console Assembly
Part # 23466980
Item Side Trim
Part # 22817347
Item Side Trim
Part # 23467516
Item Upper Trim Panel
Part # 23467113
Wrong Parts.
Item Cable
Part # 19303284
Item Mount Bracket
Part # 23467730
Edited by breid1983
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
