I sent you a pm
. Thanks for all the help. I was able to get everything working (front sub only for charging) as it should. This site is great.
Before
Edited by 02cetransam
I just tried to order a center console.
I ordered 23466995 and was told it is permanently out of stock.
The other PNs I tried to order with it were:
22776807
22817347
22817349
22995086
I have black interior with "synthesis" (plain silver) trim.
I inquired again about the console and was told the PN I actually needed was 23466980.
Currently checking availability on this part. Has anyone ordered with 23466980? Is it the same as 23466995? Why is GM changing PNs?
I used these part numbers. The only thing extra needed to buy are the two bolts and an micro usb cable to make a male to male connection are you are set go.
Here is a list of prices and corresponding item number I used for my conversion. I purchased everything through gmpartsdirect as I found them to be the cheapest over all.
Part: 22776807*
Category: All
Description: BRACKET
Min.Qty: 1
Unit Price: $13.09
Quantity: 1
Ext.Price: $13.09
Core Charge: $0.00
Part: 22817347*
Category: All
Description: PANEL
Min.Qty: 1
Unit Price: $20.62
Quantity: 1
Ext.Price: $20.62
Core Charge: $0.00
Part: 22995086*
Category: All
Description: PLATE
Min.Qty: 1
Unit Price: $145.52
Quantity: 1
Ext.Price: $145.52
Core Charge: $0.00
Part: 23466980*
Category: All
Description: CONSOLE
Min.Qty: 1
Unit Price: $318.91
Quantity: 1
Ext.Price: $318.91
Core Charge: $0.00
Part: 23467516*
Category: All
Description: PANEL
Min.Qty: 1
Unit Price: $21.27
Quantity: 1
Ext.Price: $21.27
Core Charge: $0.00
SUB TOTAL: $519.41
SHIPPING: $103.87
TAX: $0.00
TOTAL WITH TAXES: $ 623.28 * indicates special order item, which is a special order non-returnable part.
After
Looks great. I'm thinking of doing it, how hard was it? How long did it take you?
I spent quite some time on the fence as to whether or not it was worth the time and money to complete this conversion. Looking bad, it was 100% worth it as the console is so much more functional than the bench seat and besides, it looks classy. That being said, for the members who posted earlier on that said it can be completed in 2 hours, I'm not sure how that's possible. I think realistically it will take 4 to 6 hours to complete. It's not a difficult job but it just takes time especially if you want to do a clean installation, having everything working and solder all the connections. The instructions posted here at well done and I am grateful for everyone who has contributed. My only suggestion is not taking off the radio bezel stuff (not needed as you can install bracket using the cubbyhole after you remove ashtray) and using an end off your extra wiring harness to power up the usb ports as it will provide a factory connection (there are 4 wires but you only need to use 2 of them; red and black).
I'm ordering everything today. I didn't see it mentioned anywhere or I missed it, but the plate #22995086 comes with the cupholders? or with the console #23466980?
Cup holder come with the plate. The 2 missing bolts you will need are m6x1.0 x 1 inch length. All the project is doable in about 2 to 3 hours. Took 2 hours to do the last one I did.
Has anyone successfully used the glove box USB cabling on a 2015 for the console front ports?
Tried that. No sucess. Seems like it should work but it doesn't and I guess I don't care.
Hey guys I did the swap last night everything is working but I cant get the 3 USB'S TO CHARGE any help would be good... I don't need them to go to the HDU but just need them to charge.
I seen some of you guys got it to work..
Let me know...
Thanks,
So much
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,193 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
