Does anyone know which woodgrain a '14 Silverado LTZ would have? I figure I'll just match the upper console trim to my door wood grain, and I can't seem to get google to help me.
These are my options:
- Quilted Maple
- Grand Lace Wood
- Mineral Caster
- Curly Koa
Thanks in advance.
I completed the console swap today. Thanks to everyone who has posted in this thread for helping out. Everything is wired and functioning with the exception of the front USB ports. I will work on that soon.
I ended up using parts of the harness that came with the console to make it a cleaner install. That worked out perfectly.
The only issue that I ran into is that my console plate did not include the cupholder :nonod:. I bought most parts from GM Parts Direct, but bought the plate from eBay because a seller had a brand new one with the ports for $85 an it was the right color. I didn't realize it was supposed to include the cupholder. If I order one separately, it looks like they are $120. I'm not too happy about that.
Putting that aside, I really like it. It fits perfectly and looks fantastic.
Check eBay I think you can find one on there cheaper, I ordered 80% of mine on eBay
Thanks. I had looked before and $120 was the cheapest I found, but after your post I searched again and found one for $60. I guess that will have to do. I only paid $80 for the plate and ports, so I guess it is still better that the full unit from other sellers.
- Quilted Maple
- Grand Lace Wood
- Mineral Caster
- Curly Koa
Thanks in advance.
I can help some, or maybe make it worse.
Davenport Wood
Grand Momiji
Spalted Quilted Maple
Are all Chevrolet Trims
Curly Koa
Mineral Caster
Grand Lace Wood
Are all GMC trims
Also not sure all 3 of each are woodgrain. There are other trims but they are obviously not woodgrain
I think LTZ is one woodgrain and High Country is another.
i have gmc sierra 2015 base coca which parts i use to swap the console
i bought the console and the plate
the bought pannel and bracket left becasue it always says it is not available for sierra 1500 and i get confused
I drive a 2014 Sierra SLE that does not have a 110v next to the ash tray, only a 12v. For the upper trim panel kit, do I only order the panel kit WITHOUT 110v? Or is it possible to buy the one WITH 110v and route some power to it?
hmm.. i will check when i get back into my truck. i never noticed something below the 12v.
It's below and set deeper in. Might be hard to spot from certain angles unless you know it's there / are looking for it.
well thats embarassing haha such a weird spot. surprised i never noticed it
I just received my console and am in the process laying out the wiring and had a question. Couldn't I connect the USB in the console box with the 3 USM in the front of the console to make them all function? Both USB ports would connect under the passenger seat like it was with the jump seat. I have all of the connecters after removing them from the jump seat and the connectors that came with the console.
It will still only work for charging, I tried a usb to mini usb extension cord, and I was able to charge from it, but not control my music, so I just used the cord from GM that runs from the HMI, to the 3 usb's
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,201 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
