First DECENT day in a month! Washed it, vacuumed and put on a coat of Z8 Spray Seal. Good as new! :thumbs: Lot of salt came off!!!
  • Like 5
Boooo where's the 22s lol your truck convinced me to go with the SEYs, weird seeing it without them
How simply was the RX350 install?
It really depends on how ocd you are. You could easily buy the projectors from TRS and install as is with no problem. You do have to open the headlight and cut a little bit around the mounts so they will fit but that part is easy. I did however get the projectors, install clear lenses, and tune the output to straighten out the cutoff which took time. I also spent a good amount of time installing the Fx-r's and testing the output, installing the Acura TL projectors and trying to make them fit, and ultimately settling on the rx350. The TL required major cutting to the mounting surface of the headlight just to fit it in the housing which ultimately made the mounting surface to weak and I busted some mounting poles off.
Long story short is it all depends if your happy with a stock output or tuning it to your liking.
Winter wheels and tires..... 22's back on in April.
(But I think you knew that!) :lol:
beautiful truck. another zaino user i see. Cant wait(or not) until the weather gets better so i can clay, and cut out all the orange peel off this black.
kind of not looking forward to detailing this truck though. haha
for the tl projectors, were you using the original solenoid or the slim solenoid? if the original, do you think using the slim internal mount solenoid would fit without weakening the mounting surface?
http://www.hidplanet.com/forums/showthread.php?53936-TL-R-Solenoid-Converted-Bi-Xenons
There was a time that I used the entire line of Zaino products. But I've found that Z8 is such a good spray sealant, that's the only sealant I use now. I wash it every week, then wipe down with Z6. Once a month with Z8. Zaino is my Go-To detailer and sealant. (I also like Adam's detail spray.) Makes that paint super slick! :cheers:
Yeah I was aware of the slim solenoid but I used the stock one. I truthfully figured that these housings are so huge that i wouldn't need the upgrade. However that was only half the cutting. The projector bowl is so wide on these things that I had to also cut out for width. Its unfortunate because in my opinion the TL is the best bixenon out there for low and High beam and I would have loved to use them. I'm sure it can be done but my wife was starting to get angry with how much time I was spending on them so I kinda had to leave it be. For now..... :D
This is the plate that the projector mounts to looking in from the front after the headlight is opened. You can see the square portion I had to remove for the RX350 solenoid to fit properly.
You can see the solenoid on the bottom of the RX350 that you need to make room for
The blue is what I had to remove to get the TL to fit. The plate broke on the right side where it gets super thin after removing the material. Its a really low quality brittle cast of some sorts. Almost more like plastic than metal but it is indeed metal.
Edited by corwest
thanks for the info. wonder how much different the sierra internals are. i believe they were plastic(from pictures) though as opposed to the aluminum composite cast that most headlights have like the silverados. I will keep this in mind though.
Put on a set of chrome 4x4 nameplates…
Also put a flasher in my $900 C2500 to get it to safety…
Edited by Daly
    LCH14
    LCH14
  • Who's Online   2 Members, 0 Anonymous, 1,514 Guests (See full list)
