We will see how it breaks in, in a few weeks
Did you keep that valve thing?
No I had them remove it, left the rear resonator for now
No I had them remove it, left the rear resonator for nowd7cad9140d0f3bf49ce1f218fe51a329.jpg
Any drone by completely removing it ? I suppose it's the same as plugging it open but I would think there is tad bit better flow without that thing?
The drone is almost unnoticeable, today is the first day I've had it on but did take an hour trip and can say that everything has to be quite and the v4 has to be at a light throttle to even hear it enough to say it's there, really glad about that because I was worried. I decided to remove the flapper since it just restricted the flow, IMO. I love my choice so far
Today I changed my Dually D2 driving lights in my fog lights to the new DOT approved Dually lights from Rigid Industires
CCCDAF08-89AA-42B6-89B9-EDF402A37F16_zps
A282CFC6-A0EC-49BE-8F81-E4D8D1190D59_zps
F50C31DA-D649-4C7C-93D0-6679745DC566_zps
60B22959-46D5-4384-B554-D2AC0E4940DF_zps
Edited by Mike1220
Today I changed my Dually D2 driving lights in my fog lights to the new DOT approved Dually lights from Rigid IndustiresCCCDAF08-89AA-42B6-89B9-EDF402A37F16_zpsA282CFC6-A0EC-49BE-8F81-E4D8D1190D59_zpsF50C31DA-D649-4C7C-93D0-6679745DC566_zps60B22959-46D5-4384-B554-D2AC0E4940DF_zps
Can you post a pic of just the DOT Fogs on or give your impression. I've been itching to replace my floods as well but can't find any pics online of the new lights in action.
Check out this thread. I posted plenty of pics and my personal review of the lights
http://www.gm-trucks.com/forums/index.php?/topic/156170-LED-Fog-Bulbs-%26-Lights
Check out this thread. I posted plenty of pics and my personal review of the lightshttp://www.gm-trucks.com/forums/index.php?/topic/156170-LED-Fog-Bulbs-%26-Lights
Just got through with the read. Excellent write up. Thanks, looks like Rigid will be getting even more of my money.
Threw a code with less than 3k miles on the truck. P0700. Something to do with the transmission. Started shifting hard on my way home out of 1st and out of 2nd or 3rd. I have the worse luck with trannys
Sent while in 'Murica...
...washed all the salt and molasses off of it today. Damned Maryland DOT.
Looks like the DMV is getting hit with a ice storm now, they've already started to treat the roads in southern MD.
Yeah....that salt/molasses brine mix they use is hell on vehicles...and the deer LOVE it. The biggest salt lick in the country...MD highways.
That's why I just spent a fortune on a grille guard.
My ebay $50 bed mat arrived yesterday, so I got that installed.
Also added a cargo bar to keep stuff close to the tail gate since I added the bed cover.
I think my wheels arrived yesterday but I wasn't home and missed the fedex guy.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,243 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
