man i feel dumb being the only person spent more than 10 monutes on this damn thing
I go to push in and its hittin crap and no place for it to sink in or a slot for it
Did the stock trim piece have that "guide"? As I recall, it fit into a slot or something as a guide on mine. I did not cut anything on mine - it only took me 10 minutes to do this mod. Edited by chuckl1218
Yeah there is this packet with 5 pages of pictures... but its not really instructions idk what the hell its saying. I was also beyond frustrated so that didnt help
So what I did was: I aligned the Assist Handle Assembly with the pilar similar to the original trim. Then inserted the bottom edge "integral locator pin (x)" into the dash. Once this was positioned, the "integral clip (y)" would align to a slot in the pilar. Then I pressed the top of the Assist Handle Assembly toward the pilar. At this point, the bolt holes lined up, so I installed the bolts and bolt covers...done.
I hope this helps.
the problem was that point piece, i got everything else 75% of the way done. There just wasnt anywhere for that piece to go so its pressing against the frame. I pushed hard a cpl times but really didnt do anything.
The way you described is about what i did besides putting in the bolts. Im sure once im relaxed and less frustrated with it I can figure it out
That piece fit right into a circular hole which is BELOW the black airbag tether for the original thing. If you want a clean install with zero cutting, you have to pry the black tether out. It's hard, because it's tough, I had to stick a screwdriver below it and apply a lot of force. But if you do that, everything fits just dandy.
Added GMC caliper covers
Ron,
Like the covers. Where did you get them?
Thanks...
Also, I just finished installing an Airaid MIT. Looking forward to seeing if it makes a difference.
Edited by Hisdem
Ron,
Thanks...
I got them from carid.com. They have red and black ones. They have some engraved with GMC or Denali. Or you own custom message.
Keep us posted on that. I'm curious as well.
I don't know if it's really the MIT or my head messing with me, but it does feel a tad more alive I guess you could say. Seems like I don't have to push the throttle as far. Again it could just be my mind playing tricks on me. I still have the stock filter so I don't think it did much of anything.
I didn't buy it for performance anyways. I got it to make it easier to get to things and to clean up the engine bay.
I got it to see if I get an MPG increase. I've driven only 70 miles so far, so not enough to test that. But I have noticed that in regular acceleration, in the 1000-2700 RPM range that the engine sounds a LOT more like a V8 should. That smooth roar is now there.
Even if I don't see an improvement in mileage, the MIT was worth it just for that sound and how much easier it made it to access the engine bay.
The MPGs seems the same. As for the sound, it's hard for me to tell since I put the MIT on after getting the exhaust done and the exhaust is aggressive. I want to think it helped a tad with throttle response, but like I said, my mind could be playing tricks on me.
I'm hoping one day I can get some headers and a tune.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,284 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
