You have a part number? Everytime I go to get one these part stores say that they don't even have a part number for one
Ac Delco CF188 and I think gm part is 23281440
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
Edited by NitroDatsik
Ac Delco CF188 and I think gm part is 22808781
DROPKICK Edition
Dealer only?
Dealer only?
Na, i got mine off Amazon.
DROPKICK Edition
ffa97f49f9c3c595d93f615b6b367607.jpg got it from Amazon tho dealers what like $30
Dealer only?
Walmart claims to have em for $18, I'll check my local wally world see if they're in stock. If so I'll get one and do it today, if not I'll just order one online
I see K&N has them for $39. I might just buy 2 and swap them out every 6mos.
Clay-barred today the truck today. Also plasti-dipped my steering wheel bowtie to match the other 2 i previously did, (grill and tailgate)post-148296-0-22153600-1456622014_thumb.jpgpost-148296-0-83551600-1456622035_thumb.jpgpost-148296-0-42653900-1456622054_thumb.jpg
Well.. you all picked black......
Not a fan of those wheels, but truck is sharp! What tires? Toyo M/T?
Sent from my XT1254 using Tapatalk
Truck looks so good
Truck looks so good
Truck looks so good
Truck looks so good
Toyo R\T.. 33x12.50
That's a sharp looking tire, how does it ride compared to the M/T? Little quieter...
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
